do you use someone's secondary routes? I plan the platform and I need the components to draw always perpendicular to the adjacent track. I have set up secondary routes, see the picture. At the outer platform, everything works. Not at the island's two-sided platform. Can you please advise me?
I am sorry for my English, greetings from the Czech republic
That is the way it does work. Templates are created perpendicular to the reference until points are beyond the secondary alignment, then construction is done perpendicular to the secondary alignment. In your case you must create a corridor from the adjacent track. You will probably have to control the edge using a point from the main track.
