XIN: not showing any selection in Geometry commands
1. In Projectwise: loaded legacy XIN file into DGN file that has geometry created by using legacy methods (sorry, everyone hates that new DGN-based method). When trying to load any preferences or style into View geometry routines (View Horizontal Geometry  or View Stationing), the pull down tabs where normally styles/ preferences  can be selected, are empty. I know the XIN file is NOT empty.
2. I exported DGN, ALG and XIN out of Projectwise and re-opened, the same results are described above.
3. The new Project Explorer is showing all styles on XIN file, perfectly synced with Feature Definition.
What is the problem? Why XIN data is not showing where it supposed to? Any suggestions?
