I'm testing out OpenRail ConceptStation (10.00.07.27) and was wondering whether it's possible to import a BRT turnout library (.xml or .txt), or are we limited to the pre-installed ones?
Paul
Have a look at circa 30 seconds in to this video
https://communities.bentley.com/products/rail_design/w/rail_design__wiki/39662/turnout-import
KeyIn the command RAIL TURNOUT IMPORT and select an XML from the list
This is how I imported the NR RE/PW XMLs into OpenRail
A
Thanks for the reply Alastair. However, I'm looking at ConceptStation rather than Designer, this seems to use a different file format for the turnouts and there doesn't appear to be an import option.
Ah Paul - I got too excited thinking I could help that I didn't read the question, just like in my GCSEs...…..
Unfortunately I cannot help, as my trial licence of ConecptStation has run out.
My initial thinking on my limited testing, is that the turnout geometries for Concept Station are subtly different to OpenRail Designer, maybe it has something to do with their integration with the templates based tools.
Will follow this thread with interest though to see the resolutions.
Sorry but for the moment there is no customization in ConceptStation. Maybe through the components center (TechPreview) but I didn't investigate much to check if (how) it is already possible there. Some components are not only a basic "cell" so need extra data. Turnouts are a typical example.
Components Center is certainly the required place to add such information but I don't see any turnout here.
Thanks for the response, jpln.
I can't see 'Components Center' in my version (10.00.07.27) - would this be in a later version?
