code error 65539 importing a dgn file into OPENRAIL CONCEPTSTATION
When importing a dgn file with an alignment from ORD into OPEN RAIL CONCEPTSTATION the next message appears:
Import failed: DgnDbStatus error code-65539:contact support
I'm using OPEN RAIL CONCEPTSTATION V 10.00.08.20 and OPEN ROADS DESIGNER V 10.05.00.30. The reason for importing the alignment into a dgn  is to use it for building a double track, if import a alg file, CONCPTSTATION ask me for a template and then I can not design the double track. The dgn file has only one 3d design model in the same coordinate system as OPEN RAIL CONCEPTSTATION
