I have drawn two "Lines Between Points" that are at a right angle to eachother and are able to create a spiral
I select "Spiral Between Two Elements", can select one element, when I go to select the second, it says "Invalid Geometry Type"
Weird thing is, I can select a curved portion of a reverse curve I created previously.
Earlier in this session it let me do it, and I do not recall messing with any settings.
Not supported geometry. You can't create a spiral between 2 straights. We don't support Spiral-radius with length=0-Spiral
