Just noticed that we got the option for turnout annotation (as cell) in SS4 ver.904
what I se as a very useful function when there is need to separate the existing from the new turnouts,
but the cell landed with origo on crossings (.0) point in turnout and not on the tip point (.1).
Is that working as designed?
Asmir
Short answer is yes.
The cells are aligned with the cell origin at the .0 point. This is working as intended
Couple of things to note
- Cells are defined as being left hand leading when creating them
- Cells do not bend in contraflexure or similarflexure
- Cells including text will be mirrored if they are not left hand facing turnouts.
Answer Verified By: Asmir Kapetanovic
