I have made a simple alignement in ord (Version 10.06.00.38)
The alignement exists out horizontal, vertical, speed and cant.
If i do an export to XML with "export geometry" it does not include the speed and cant in the xml file
I did try this with LandXML version 1.2 and version 2.0 but both don't take the speed and cant.
How can i make an export to xml thats including the speed and cant?
Best regards,
Ariaan
I logged an enhancement request to handle speed and cant in LandXML
An alternative could be ifc depending on software you want to export to.
Answer Verified By: Kivanch
Thank you Jean-Pierre for logging, I will add this to roadmap.
Thanks for you're reaction Jean-Pierre
Lets say for a project when we finished our alignement we have to make an export for our client.
The client will check the alignement. The client uses ther own software for this and other clients uses AutoDesk or Bentley software.
Most can work with XML files.
I have not looked into ifc how this could help but this could help.
I hope they can add this into the xml export.
Is this fixed or going to be fixed? Because i still cannot export design to xml with cant and speed. I'm using version 10.07.00.56 so not the latest version
Unfortunately still not issued even in 2019_R2. I checked that enhancement is logged and approved.
