What can I use from OpenRail ConceptStation in OpenRail ?
May I ask what kind of information can I use from project in OpenRail ConceptStation in OpenRail ? I have designed a rail track in ConceptStation with all parameters you can have in ConceptStation.
I am using ConceptStation for school project, as a final work so I need "something to print".
Can I transfer data from ConceptStation to OpenRail and create a pdf file of Longitudinal profile, direction, cross-sections ?
I know that ConceptStation has .dgn files in export but I don´t know OpenRail at all so that´s the main reason why I am asking this.
Thank you very much for your responds.
Have a nice day!
  • Actually the geometry export is based on legacy Rail Track files. You can export ITL, ALG, IRD, TIN and DGN to reference all geometries (bridges, catenary system, ...).
    So you can:
    create a DGN in OpenRail Designer (3D seed)
    • Create terrain from file (TIN)
    create a DGN in OpenRail Designer (2D seed)
    • import ALG (in 2D model)
    • In the 3D model:
      • Reference terrain (dgn above)
      • Reference 3SM (textured)
      • Reference the DGN exported from ConceptStation (all 3D modelling)
    • import IRD (in 2D model)
Reply
    So you can:
    • In the 3D model:
