How to Export Terrain Model TM in ASCII file (.xyz - Only Point Data)?
I've created a Complex TM merging different TM models; now i want to export Complex TM in a "points format" like ASCII (.xyz) or .pod
Davide
In another post, I give a solution if you want to export/annotate a grid of points.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/191410/ord-annotate-terrain-elevation-on-a-grid/635040#635040
