I am trying to create a preliminary underground alignment on ConceptStation and I have encountered two issues:
1. I am trying to change the tunnel diameter to 5.76m but the smallest I am able to get it is 10.08m as it doesn't allow the diameter to be input.
2. I don't seem to be able to have a turnout in a tunnel, is this feature not available?
If anyone could provide answers I would appreciate it.
1. the diameter is automatically calculated from template, walkway width, thickness, ... You can't set it manually
2. I have been able to place a turnout in the tunnel for a crossover. However, the tunnel does not adjust to the turnout. So it is ok for crossover. I have to test more if you want to connect tubes. Not sure it is supported actually
