Openrail - Arema Turnouts - where does the dimension come from?
Where does the dimension of the different AREMA turnout come from?  I'm using a number 8 straight Arema standard turnout and I dont understand from where the dimension come from.  Number 8 switch are around 28.8m long for Arema but in Openrail they are more around 23m long.  So where does this number come from?  The angle ratio is good but not the lenght.
Should I check ALL the other switch?
Please provide from where you got those numbers or verify them.
