Project object to profile/cross section view
Hello everyone,
I wanted to know if it was possible to project cells into the profile view and cross section view.
I need to project in the profile view and cross section view the noise barriers inserted in the plan view.
I need to create drawings where the noise barriers are visible in both profile and section view.
Davide Porzio
Italferr S.p.A.
Direzione Tecnica
Sviluppo BIM
  • You can use a cell to mark the intersection point of the barrier with the alignment on the profile view, and the intersected barrier on the cross section.
    It is a matter of feature definition where you have to set an element template with a cell to display on cross section or intersected profile.
    You can find some example in the delivered configuration, like crash barrier.
    You can't project points on the profile or cross section for now.
Reply
