When placing named boundaries the station is not correct see video>
https://vimeo.com/360971704
//Christiaan
It looks like it is placed at stations that are even of 15m. It is normal behavior if station lock is 1
# Station Lock# If set to 1 then stations for various commands are adjusted to stay at even values.# For example, template drops will adjust to be at even stations in the event of an# equation that could cause it to do otherwise. If not set or set to FALSE, then the# station values will be maintained at the specified increments. CIVIL_DEFAULT_STATION_LOCK = 1
Hi, When changing this value it doesn't work on my end?
It looks like there is an issue. I am investigating
