Moving from MX Rail to ORD
Dear , I tried emailing you regarding this matter last year, but the files wouldn't attach and then I think the email in general must have just got lost somewhere along the way. Currently I'm trying to make the move from "MX V8 XM Edition, 08.09.05.18" to ORD, and was hoping you could help with some of the process. These are the two main style sets we use in MX...
Existing survey style set used. "MfW Detail Survey.pss" file contents:
   Style Set Created by version 1 of the Style Set Editor on the 28/01/00
   Style Set Editor file: MfW Detail Survey
   *** Manual alterations to this file are not advised! ***
   Global Options Start
000GLOBAL AUTOCAD LAYERNAME =
000GLOBAL MICROSTATION LEVEL NAME =
000GLOBAL MICROSTATION LEVEL NUMBER = 0
000805,1=1,4=0.300
000806,1=1
000808,4=0.180,5=3,6=1.000
000810
000812,1=MOSS,4=0.100
   Global Options End
   String Naming Convention
   Feature                             | Partial Name  | Subreference| String Type | AutoCAD Grouped Feature Layer Name | MicroStation Grouped Feature Level Name | MicroStation level Number | Default CAD Grouped Feature |
   Start %0
   Boundary Strings                                  'BO  '          'BDRY'         2             ''    ''    '0'    'False'
   Circles (Scaled)                                  'CIR '          'CIR '         8             ''    ''    '0'    'False'
   Slope Signatures                                  'SS  '          'HACE'         2             ''    ''    '0'    'False'
   Rectangles (Scaled)                               'REC '          'REC '         8             ''    ''    '0'    'False'
   Survey Stations                                   'PSS '          'SSTA'         4             ''    ''    '0'    'False'
   Text Strings                                      '*   '          '    '         16384         ''    ''    '0'    'False'
   Buildings (Frontage)                              'BF  '          '    '         2             ''    ''    '0'    'False'
   Buildings (General)                               'BG  '          '    '         2             ''    ''    '0'    'False'
   Buildings (Solid-Sided Left)                      'BLC '          '    '         2             ''    ''    '0'    'False'
   Buildings (Open-Sided Left)                       'BLO '          '    '         2             ''    ''    '0'    'False'
   Buildings (Solid-Sided Right)                     'BRC '          '    '         2             ''    ''    '0'    'False'
   Buildings (Open-Sided Right)                      'BRO '          '    '         2             ''    ''    '0'    'False'
   Large Road Signs                                  'BSI '          '    '         65536         ''    ''    '0'    'False'
   Buildings (All)                                   'B   '          '    '         2             ''    ''    '0'    'False'
   Centrelines                                       'CC  '          '    '         2             ''    ''    '0'    'False'
   Carriageways/Channels                             'C   '          '    '         2             ''    ''    '0'    'False'
   Ditches (Bottom)                                  'DB  '          '    '         2             ''    ''    '0'    'False'
   Ditches (Top)                                     'DT  '          '    '         2             ''    ''    '0'    'False'
   Ditches (All)                                     'D   '          '    '         2             ''    ''    '0'    'False'
   Earthworks (General)                              'EG  '          '    '         2             ''    ''    '0'    'False'
   Embankments (Bottom)                              'EMB '          '    '         2             ''    ''    '0'    'False'
   Embankments (Top)                                 'EMT '          '    '         2             ''    ''    '0'    'False'
   Fences (Secure)                                   'FS  '          '    '         2             ''    ''    '0'    'False'
   Fences (Open)                                     'F   '          '    '         2             ''    ''    '0'    'False'
   Gates                                             'G   '          '    '         2             ''    ''    '0'    'False'
   Hedges                                            'H   '          '    '         2             ''    ''    '0'    'False'
   Interfaces                                        'INT '          '    '         2             ''    ''    '0'    'False'
   Irrigation Lines                                  'I   '          '    '         2             ''    ''    '0'    'False'
   Kerbs                                             'K   '          '    '         2             ''    ''    '0'    'False'
   Spot Levels                                       'L   '          '    '         2             ''    ''    '0'    'False'
   Overhead Details/Cables                           'OVR '          '    '         2             ''    ''    '0'    'False'
   Bracken                                           'PBA '          '    '         65536         ''    ''    '0'    'False'
   Conifer                                           'PCO '          '    '         65536         ''    ''    '0'    'False'
   Manhole Cover (Large Square)                      'PCS '          '    '         65536         ''    ''    '0'    'False'
   Culverts                                          'PCU '          '    '         65536         ''    ''    '0'    'False'
   Deciduous Tree                                    'PDE '          '    '         65536         ''    ''    '0'    'False'
   Electricity Box (Pillar)                          'PEB '          '    '         65536         ''    ''    '0'    'False'
   Electricity Cover (Large Round)                   'PER '          '    '         65536         ''    ''    '0'    'False'
   Electricity Cover (Large Square)                  'PES '          '    '         65536         ''    ''    '0'    'False'
   Fire Hydrant                                      'PFH '          '    '         65536         ''    ''    '0'    'False'
   Gas Cover (Large Round)                           'PGR '          '    '         65536         ''    ''    '0'    'False'
   Gas Cover (Large Square)                          'PGS '          '    '         65536         ''    ''    '0'    'False'
   Gullies                                           'PGU '          '    '         65536         ''    ''    '0'    'False'
   Gas Valve                                         'PGV '          '    '         65536         ''    ''    '0'    'False'
   Heathland                                         'PHT '          '    '         65536         ''    ''    '0'    'False'
   Large Inspection Chamber (Round)                  'PIR '          '    '         65536         ''    ''    '0'    'False'
   Large Inspection Chamber(Square)                  'PIS '          '    '         65536         ''    ''    '0'    'False'
   Marsh                                             'PMA '          '    '         65536         ''    ''    '0'    'False'
   Manhole Cover (Round)                             'PMR '          '    '         65536         ''    ''    '0'    'False'
   Manhole Cover (Square)                            'PMS '          '    '         65536         ''    ''    '0'    'False'
   Manhole Cover (Triangular)                        'PMT '          '    '         65536         ''    ''    '0'    'False'
   North Symbol (Patent)                             'PNT '          '    '         65536         ''    ''    '0'    'False'
   Benchmarks (Ordnance Survey)                      'POB '          '    '         65536         ''    ''    '0'    'False'
   Ordnance Survey Revision Point                    'POR '          '    '         65536         ''    ''    '0'    'False'
   Osiers                                            'POS '          '    '         65536         ''    ''    '0'    'False'
   Trig Station (Ordnance Survey)                    'POT '          '    '         65536         ''    ''    '0'    'False'
   Pylon                                             'PPY '          '    '         65536         ''    ''    '0'    'False'
   Orchard Symbol (Ordnance Survey)                  'PRC '          '    '         65536         ''    ''    '0'    'False'
   Reeds                                             'PRE '          '    '         65536         ''    ''    '0'    'False'
   Grass (Rough)                                     'PRG '          '    '         65536         ''    ''    '0'    'False'
   Scrub                                             'PSC '          '    '         65536         ''    ''    '0'    'False'
   Bench Seats                                       'PSE '          '    '         65536         ''    ''    '0'    'False'
   Saltings                                          'PSL '          '    '         65536         ''    ''    '0'    'False'
   Stop Valve                                        'PSV '          '    '         65536         ''    ''    '0'    'False'
   Trees (Small)                                     'PT1 '          '    '         65536         ''    ''    '0'    'False'
   Trees (Medium)                                    'PT2 '          '    '         65536         ''    ''    '0'    'False'
   Trees (Large)                                     'PT3 '          '    '         65536         ''    ''    '0'    'False'
   Telecom Box (Pillar)                              'PTB '          '    '         65536         ''    ''    '0'    'False'
   Benchmarks (Temporary)                            'PTM '          '    '         65536         ''    ''    '0'    'False'
   Telecom Cover (Large Round)                       'PTR '          '    '         65536         ''    ''    '0'    'False'
   Telecom Cover (Large Square)                      'PTS '          '    '         65536         ''    ''    '0'    'False'
   Manhole Cover (Large Round)                       'PUR '          '    '         65536         ''    ''    '0'    'False'
   Manhole Cover (Large Triangular)                  'PUT '          '    '         65536         ''    ''    '0'    'False'
   Water Meter                                       'PWM '          '    '         65536         ''    ''    '0'    'False'
   Water Cover (Large Round)                         'PWR '          '    '         65536         ''    ''    '0'    'False'
   Water Cover (Large Square)                        'PWS '          '    '         65536         ''    ''    '0'    'False'
   Point Features (Other)                            'P   '          '    '         65536         ''    ''    '0'    'False'
   Rails                                             'RA  '          '    '         2             ''    ''    '0'    'False'
   Stiles                                            'STY '          '    '         2             ''    ''    '0'    'False'
   Shoulders                                         'S   '          '    '         2             ''    ''    '0'    'False'
   Verges Footpaths and Tracks                       'V   '          '    '         2             ''    ''    '0'    'False'
   Walls (Low Left 0.1m - 0.5m)                      'WAL '          '    '         2             ''    ''    '0'    'False'
   Walls (Low Right 0.1m - 0.5m)                     'WAR '          '    '         2             ''    ''    '0'    'False'
   Walls (Retaining Left)                            'WRL '          '    '         2             ''    ''    '0'    'False'
   Walls (Retaining Right)                           'WRR '          '    '         2             ''    ''    '0'    'False'
   Contours (Normal)                                 'Y   '          '    '         1             ''    ''    '0'    'False'
   Contours (Prominent)                              'Z   '          '    '         1             ''    ''    '0'    'False'
   End %0
   Boundary Strings
   Declare %1
   2 - 019
019,BO,BDRY,4=6
019,4=-6
   Options %2
817,,LIST
814,3=BOUN
805,1=2
810,DASH,5=-0.500,6=-0.500,8=-0.500,9=-0.500,7=0.000
825,2=DETA
805
806
808,4=0.180
000858,7=0.000
000858,3=A001,4=-1
000001,&A001&
000859,7=0.000,10=0.000
000859,3=V002,4=1
000001,&V002&
000861,2=MXMACRO,4=1.000,7=1.000,10=0.000
815
   End Options %3
   Circles (Scaled)
   Declare %1
   2 - 019
019,CIR,CIR ,4=6
019,4=-6
   Options %2
817,,LIST
814,3=CIRC
805
810,MACR,2=OBJCIRCL,5=-1
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A003,4=-1
000001,&A003&
000859,3=V004,4=1
000001,&V004&
815
   End Options %3
   Slope Signatures
   Declare %1
   2 - 019
019,SS,HACE,4=6
019,4=-6
   Options %2
817,,LIST
814,3=SLOP
805,1=1
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A005,4=-1
000001,&A005&
000859,3=V006,4=1
000001,&V006&
815
   End Options %3
   Rectangles (Scaled)
   Declare %1
   2 - 019
019,REC,REC ,4=6
019,4=-6
   Options %2
817,,LIST
814,3=RECT
805
810,MACR,2=OBJRECT,5=-1
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A007,4=-1
000001,&A007&
000859,3=V008,4=1
000001,&V008&
815
   End Options %3
   Survey Stations
   Declare %1
   2 - 019
019,PSS,SSTA,4=6
019,4=-6
   Options %2
817,,LIST
814,3=PSSA
805,1=2
806,1=2
810
825,2=DETA
805
806
808,4=0.180
000858,7=0.000
000858,3=A009,4=-1
000001,&A009&
000859,3=V00A,4=1
000001,&V00A&
815
   End Options %3
   Text Strings
   Declare %1
   1 - *
   Options %2
817,,LIST
814,3=TEXT
806
808,4=0.180
830
805
806
808,4=0.180
000810
000858,7=0.000
000858,3=A00B,4=-1
000001,&A00B&
000859,3=V00C,4=1
000001,&V00C&
815
   End Options %3
   Declare %1
   1 - BF
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810,MACR,2=FRONTAGE,5=-1,6=-0.5
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A00D,4=-1
000001,&A00D&
000859,3=V00E,4=1
000001,&V00E&
815
   End Options %3
   Buildings (General)
   Declare %1
   1 - BG
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A00F,4=-1
000001,&A00F&
000859,3=V010,4=1
000001,&V010&
815
   End Options %3
   Declare %1
   1 - BLC
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810,MACR,2=BUILDNGL,5=-1,6=-0.1
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A011,4=-1
000001,&A011&
000859,3=V012,4=1
000001,&V012&
815
   End Options %3
   Declare %1
   1 - BLO
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810,MACR,2=OPNBLDGL,8=-8.000,6=-1.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A013,4=-1
000001,&A013&
000859,3=V014,4=1
000001,&V014&
815
   End Options %3
   Declare %1
   1 - BRC
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810,MACR,2=BUILDNGR,5=-1,6=-0.1
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A015,4=-1
000001,&A015&
000859,3=V016,4=1
000001,&V016&
815
   End Options %3
   Declare %1
   1 - BRO
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810,MACR,2=BUILDNGR,8=-4.000,6=-1.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A017,4=-1
000001,&A017&
000859,3=V018,4=1
000001,&V018&
815
   End Options %3
   Large Road Signs
   Declare %1
   1 - BSI
   Options %2
817,,LIST
814,3=BSIG
805
810,MACR,2=BIGSIGNS,8=-2.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A019,4=-1
000001,&A019&
000859,3=V01A,4=1
000001,&V01A&
815
   End Options %3
   Buildings (All)
   Declare %1
   1 - B
   Options %2
817,,LIST
814,3=BLDS
805,1=5
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A01B,4=-1
000001,&A01B&
000859,3=V01C,4=1
000001,&V01C&
815
   End Options %3
   Centrelines
   Declare %1
   1 - CC
   Options %2
817,,LIST
814,3=CCEN
805,1=2
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A01D,4=-1
000001,&A01D&
000859,3=V01E,4=1
000001,&V01E&
815
   End Options %3
   Declare %1
   1 - C
   Options %2
817,,LIST
814,3=CHAN
805,1=6
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A01F,4=-1
000001,&A01F&
000859,3=V020,4=1
000001,&V020&
815
   End Options %3
   Ditches (Bottom)
   Declare %1
   1 - DB
   Options %2
817,,LIST
814,3=DTCH
805,1=9
810
825,2=DETA
805
806
808,4=0.180
000858,7=0.000
000858,3=A021,4=-1
000001,&A021&
000859,3=V022,4=1
000001,&V022&
815
   End Options %3
   Ditches (Top)
   Declare %1
   1 - DT
   Options %2
817,,LIST
814,3=DTCH
805,1=9
810
825,2=DETA
805
806
808,4=0.180
000858,7=0.000
000858,3=A023,4=-1
000001,&A023&
000859,3=V024,4=1
000001,&V024&
815
   End Options %3
   Ditches (All)
   Declare %1
   1 - D
   Options %2
817,,LIST
814,3=DTCH
805,1=9
810,DASH,5=2.000,6=0.500,8=0.500,9=0.500,7=0.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A025,4=-1
000001,&A025&
000859,3=V026,4=1
000001,&V026&
815
   End Options %3
   Declare %1
   1 - EG
   Options %2
817,,LIST
814,3=EWRK
805,1=6
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A027,4=-1
000001,&A027&
000859,3=V028,4=1
000001,&V028&
815
   End Options %3
   Declare %1
   1 - EMB
   Options %2
817,,LIST
814,3=EMBM
805
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A029,4=-1
000001,&A029&
000859,3=V02A,4=1
000001,&V02A&
815
   End Options %3
   Embankments (Top)
   Declare %1
   1 - EMT
   Options %2
817,,LIST
814,3=EMBM
805
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A02B,4=-1
000001,&A02B&
000859,3=V02C,4=1
000001,&V02C&
815
   End Options %3
   Fences (Secure)
   Declare %1
   1 - FS
   Options %2
817,,LIST
814,3=FENS
805,1=7
810,MACR,2=SECFENCE,8=-10.000,6=-1.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A02D,4=-1
000001,&A02D&
000859,3=V02E,4=1
000001,&V02E&
815
   End Options %3
   Fences (Open)
   Declare %1
   1 - F
   Options %2
817,,LIST
814,3=FENO
805,1=7
810,MACR,2=OPNFENCE,8=-30.000,6=-1.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A02F,4=-1
000001,&A02F&
000859,3=V030,4=1
000001,&V030&
815
   End Options %3
   Gates
   Declare %1
   1 - G
   Options %2
817,,LIST
814,3=GATE
805,1=7
810,MACR,2=GATESYMB,5=-2,6=-1
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A031,4=-1
000001,&A031&
000859,3=V032,4=1
000001,&V032&
815
   End Options %3
   Hedges
   Declare %1
   1 - H
   Options %2
817,,LIST
814,3=HEDG
805,1=3
810,MACR,2=HEDGE,8=-10.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A033,4=-1
000001,&A033&
000859,3=V034,4=1
000001,&V034&
815
   End Options %3
   Interfaces
   Declare %1
   1 - INT
   Options %2
817,,LIST
814,3=INTE
805,1=104
810,DASH,5=-0.500,6=-1.000,8=-1.500,9=-1.000,7=0.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A035,4=-1
000001,&A035&
000859,3=V036,4=1
000001,&V036&
815
   End Options %3
   Irrigation Lines
   Declare %1
   1 - I
   Options %2
817,,LIST
814,3=IRRI
805,1=4
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A037,4=-1
000001,&A037&
000859,3=V038,4=1
000001,&V038&
815
   End Options %3
   Kerbs
   Declare %1
   1 - K
   Options %2
817,,LIST
814,3=KERB
805,1=8
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A039,4=-1
000001,&A039&
000859,3=V03A,4=1
000001,&V03A&
815
   End Options %3
   Spot Levels
   Declare %1
   1 - L
   Options %2
817,,LIST
814,3=SPOT
805
810
806
825,2=DETA
805
806
808,4=0.180
000858,7=0.000
000858,3=A03B,4=-1
000001,&A03B&
000859,3=V03C,4=1
000001,&V03C&
815
   End Options %3
   Declare %1
   1 - OVR
   Options %2
817,,LIST
814,3=OVRH
805
810,MACR,2=OVERHEAD,8=-36.000,6=-6.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A03D,4=-1
000001,&A03D&
000859,3=V03E,4=1
000001,&V03E&
815
   End Options %3
   Bracken
   Declare %1
   1 - PBA
   Options %2
817,,LIST
814,3=PBAK
805,1=3
810
861,2=BRACKENS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A03F,4=-1
000001,&A03F&
000859,3=V040,4=1
000001,&V040&
000825
815
   End Options %3
   Conifer
   Declare %1
   1 - PCO
   Options %2
817,,LIST
814,3=PCON
805,1=3
810
861,2=CONIFERS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A041,4=-1
000001,&A041&
000859,3=V042,4=1
000001,&V042&
000825
815
   End Options %3
   Declare %1
   1 - PCS
   Options %2
817,,LIST
814,3=PUCS
805
810
861,2=SQMHNOID,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A043,4=-1
000001,&A043&
000859,3=V044,4=1
000001,&V044&
000825
815
   End Options %3
   Culverts
   Declare %1
   1 - PCU
   Options %2
817,,LIST
814,3=DCUL
805,1=9
810,MACR,2=DIDRCULV,8=-18.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A045,4=-1
000001,&A045&
000859,3=V046,4=1
000001,&V046&
815
   End Options %3
   Deciduous Tree
   Declare %1
   1 - PDE
   Options %2
817,,LIST
814,3=PDEC
805,1=3
810
861,2=DECIDUOS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A047,4=-1
000001,&A047&
000859,3=V048,4=1
000001,&V048&
000825
815
   End Options %3
   Declare %1
   1 - PEB
   Options %2
817,,LIST
814,3=PEBP
805
810
861,2=ELECBOXP,4=0.375,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A049,4=-1
000001,&A049&
000859,3=V04A,4=1
000001,&V04A&
000825
815
   End Options %3
   Declare %1
   1 - PER
   Options %2
817,,LIST
814,3=PECR
805
810
861,2=ROUNDECR,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A04B,4=-1
000001,&A04B&
000859,3=V04C,4=1
000001,&V04C&
000825
815
   End Options %3
   Declare %1
   1 - PES
   Options %2
817,,LIST
814,3=PECS
805
810
861,2=SQUAREEC,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A04D,4=-1
000001,&A04D&
000859,3=V04E,4=1
000001,&V04E&
000825
815
   End Options %3
   Fire Hydrant
   Declare %1
   1 - PFH
   Options %2
817,,LIST
814,3=PFHY
805
810
861,2=FIREHYDR,4=0.375,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A04F,4=-1
000001,&A04F&
000859,3=V050,4=1
000001,&V050&
000825
815
   End Options %3
   Declare %1
   1 - PGR
   Options %2
817,,LIST
814,3=PGCR
805
810
861,2=ROUNDGCR,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A051,4=-1
000001,&A051&
000859,3=V052,4=1
000001,&V052&
000825
815
   End Options %3
   Declare %1
   1 - PGS
   Options %2
817,,LIST
814,3=PGCS
805
810
861,2=SQUAREGC,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A053,4=-1
000001,&A053&
000859,3=V054,4=1
000001,&V054&
000825
815
   End Options %3
   Gullies
   Declare %1
   1 - PGU
   Options %2
817,,LIST
814,3=GULY
805
810
861,2=GULLY,4=-0.450,10=0.000
805
806
808,4=0.180
000858,7=0.000
000858,3=A055,4=-1
000001,&A055&
000859,3=V056,4=1
000001,&V056&
000825
815
   End Options %3
   Gas Valve
   Declare %1
   1 - PGV
   Options %2
817,,LIST
814,3=PGVL
805
810
861,2=GASVALVE,4=0.375,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A057,4=-1
000001,&A057&
000859,3=V058,4=1
000001,&V058&
000825
815
   End Options %3
   Heathland
   Declare %1
   1 - PHT
   Options %2
817,,LIST
814,3=PHTH
805,1=3
810
861,2=HETHLAND,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A059,4=-1
000001,&A059&
000859,3=V05A,4=1
000001,&V05A&
000825
815
   End Options %3
   Declare %1
   1 - PIR
   Options %2
817,,LIST
814,3=PICR
805
810
861,2=ROUNDICR,4=0.390,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A05B,4=-1
000001,&A05B&
000859,3=V05C,4=1
000001,&V05C&
000825
815
   End Options %3
   Declare %1
   1 - PIS
   Options %2
817,,LIST
814,3=PICS
805
810
861,2=SQUAREIC,4=0.390,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A05D,4=-1
000001,&A05D&
000859,3=V05E,4=1
000001,&V05E&
000825
815
   End Options %3
   Marsh
   Declare %1
   1 - PMA
   Options %2
817,,LIST
814,3=PMAR
805,1=3
810
861,2=MARSHSSS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A05F,4=-1
000001,&A05F&
000859,3=V060,4=1
000001,&V060&
000825
815
   End Options %3
   Declare %1
   1 - PMR
   Options %2
817,,LIST
814,3=PMHR
805
810
861,2=ROUNDMHL,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A061,4=-1
000001,&A061&
000859,3=V062,4=1
000001,&V062&
000825
815
   End Options %3
   Declare %1
   1 - PMS
   Options %2
817,,LIST
814,3=PMHS
805
810
861,2=SQUAREMH,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A063,4=-1
000001,&A063&
000859,3=V064,4=1
000001,&V064&
000825
815
   End Options %3
   Declare %1
   1 - PMT
   Options %2
817,,LIST
814,3=PMHT
805
810
861,2=TRIAGRMH,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A065,4=-1
000001,&A065&
000859,3=V066,4=1
000001,&V066&
000825
815
   End Options %3
   Declare %1
   1 - PNT
   Options %2
817,,LIST
814,3=PNTH
805
810
861,2=NORTHING,4=4.000,7=2.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A067,4=-1
000001,&A067&
000859,3=V068,4=1
000001,&V068&
000825
815
   End Options %3
   Declare %1
   1 - POB
   Options %2
817,,LIST
814,3=POBM
805
810
861,2=ORDSRVBM,4=0.300,7=0.300
805
806
808,4=0.180
000858,7=0.000
000858,3=A069,4=-1
000001,&A069&
000859,3=V06A,4=1
000001,&V06A&
000825
815
   End Options %3
   Declare %1
   1 - POR
   Options %2
817,,LIST
814,3=PORP
805
810
861,2=OSRVSNPT,4=0.300,7=0.300
805
806
808,4=0.180
000858,7=0.000
000858,3=A06B,4=-1
000001,&A06B&
000859,3=V06C,4=1
000001,&V06C&
000825
815
   End Options %3
   Osiers
   Declare %1
   1 - POS
   Options %2
817,,LIST
814,3=POSI
805,1=3
810
861,2=POSIERSS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A06D,4=-1
000001,&A06D&
000859,3=V06E,4=1
000001,&V06E&
000825
815
   End Options %3
   Declare %1
   1 - POT
   Options %2
817,,LIST
814,3=POSN
805,1=1
810
861,2=OSTRGSTN,4=0.300,7=0.300
805
806
808,4=0.180
000858,7=0.000
000858,3=A06F,4=-1
000001,&A06F&
000859,3=V070,4=1
000001,&V070&
000825
815
   End Options %3
   Pylon
   Declare %1
   1 - PPY
   Options %2
817,,LIST
814,3=PEPY
805
810
861,2=ELEPYLON,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A071,4=-1
000001,&A071&
000859,3=V072,4=1
000001,&V072&
000825
815
   End Options %3
   Declare %1
   1 - PRC
   Options %2
817,,LIST
814,3=PRCH
805,1=3
810
861,2=ORCHARDS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A073,4=-1
000001,&A073&
000859,3=V074,4=1
000001,&V074&
000825
815
   End Options %3
   Reeds
   Declare %1
   1 - PRE
   Options %2
817,,LIST
814,3=PRED
805,1=3
810
861,2=REEDSSSS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A075,4=-1
000001,&A075&
000859,3=V076,4=1
000001,&V076&
000825
815
   End Options %3
   Grass (Rough)
   Declare %1
   1 - PRG
   Options %2
817,,LIST
814,3=PGRS
805,1=3
810
861,2=RUGHGRAS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A077,4=-1
000001,&A077&
000859,3=V078,4=1
000001,&V078&
000825
815
   End Options %3
   Scrub
   Declare %1
   1 - PSC
   Options %2
817,,LIST
814,3=PSCR
805,1=3
810
861,2=SCRUBSSS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A079,4=-1
000001,&A079&
000859,3=V07A,4=1
000001,&V07A&
000825
815
   End Options %3
   Bench Seats
   Declare %1
   1 - PSE
   Options %2
817,,LIST
814,3=PSET
805
810
861,2=SEATSYMB,4=0.700,7=0.265
805
806
808,4=0.180
000858,7=0.000
000858,3=A07B,4=-1
000001,&A07B&
000859,3=V07C,4=1
000001,&V07C&
000825
815
   End Options %3
   Saltings
   Declare %1
   1 - PSL
   Options %2
817,,LIST
814,3=PSLT
805,1=3
810
861,2=SALTINGS,4=0.500,7=0.500
805
806
808,4=0.180
000858,7=0.000
000858,3=A07D,4=-1
000001,&A07D&
000859,3=V07E,4=1
000001,&V07E&
000825
815
   End Options %3
   Stop Valve
   Declare %1
   1 - PSV
   Options %2
817,,LIST
814,3=SVLV
805,1=1
810
861,2=STOPVALV,4=0.375,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A07F,4=-1
000001,&A07F&
000859,3=V080,4=1
000001,&V080&
000825
815
   End Options %3
   Trees (Small)
   Declare %1
   1 - PT1
   Options %2
817,,LIST
814,3=PTR1
805,1=3
810
861,2=TREESYMB,4=0.800,7=0.800
805
806
808,4=0.180
000858,7=0.000
000858,3=A081,4=-1
000001,&A081&
000859,3=V082,4=1
000001,&V082&
000825
815
   End Options %3
   Trees (Medium)
   Declare %1
   1 - PT2
   Options %2
817,,LIST
814,3=PTR2
805,1=3
810
861,2=TREESYMB,4=1.400,7=1.400
805
806
808,4=0.180
000858,7=0.000
000858,3=A083,4=-1
000001,&A083&
000859,3=V084,4=1
000001,&V084&
000825
815
   End Options %3
   Trees (Large)
   Declare %1
   1 - PT3
   Options %2
817,,LIST
814,3=PTR3
805,1=3
810
861,2=TREESYMB,4=2.000,7=2.000
805
806
808,4=0.180
000858,7=0.000
000858,3=A085,4=-1
000001,&A085&
000859,3=V086,4=1
000001,&V086&
000825
815
   End Options %3
   Declare %1
   1 - PTB
   Options %2
817,,LIST
814,3=PTBX
805
810
861,2=TELECBOX,4=0.390,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A087,4=-1
000001,&A087&
000859,3=V088,4=1
000001,&V088&
000825
815
   End Options %3
   Declare %1
   1 - PTM
   Options %2
817,,LIST
814,3=PTBM
805
810
861,2=TBMSYMB,4=0.875,7=0.275
805
806
808,4=0.180
000858,7=0.000
000858,3=A089,4=-1
000001,&A089&
000859,3=V08A,4=1
000001,&V08A&
000825
815
   End Options %3
   Declare %1
   1 - PTR
   Options %2
817,,LIST
814,3=PTCR
805
810
861,2=ROUNDTCR,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A08B,4=-1
000001,&A08B&
000859,3=V08C,4=1
000001,&V08C&
000825
815
   End Options %3
   Declare %1
   1 - PTS
   Options %2
817,,LIST
814,3=PTCS
805
810
861,2=SQUARETC,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A08D,4=-1
000001,&A08D&
000859,3=V08E,4=1
000001,&V08E&
000825
815
   End Options %3
   Declare %1
   1 - PUR
   Options %2
817,,LIST
814,3=PMHS
805
810
805
806
808,4=0.180
000858,7=0.000
000858,3=A08F,4=-1
000001,&A08F&
000859,3=V090,4=1
000001,&V090&
000825
815
   End Options %3
   Declare %1
   1 - PUT
   Options %2
817,,LIST
814,3=PUCT
805
810
861,2=TRMHNOID,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A091,4=-1
000001,&A091&
000859,3=V092,4=1
000001,&V092&
000825
815
   End Options %3
   Water Meter
   Declare %1
   1 - PWM
   Options %2
817,,LIST
814,3=PWMR
805
810
861,2=WATERMTR,4=0.390,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A093,4=-1
000001,&A093&
000859,3=V094,4=1
000001,&V094&
000825
815
   End Options %3
   Declare %1
   1 - PWR
   Options %2
817,,LIST
814,3=PWCR
805
810
861,2=ROUNDWCR,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A095,4=-1
000001,&A095&
000859,3=V096,4=1
000001,&V096&
000825
815
   End Options %3
   Declare %1
   1 - PWS
   Options %2
817,,LIST
814,3=PWCS
805
810
861,2=SQUAREWC,4=0.465,7=0.150
805
806
808,4=0.180
000858,7=0.000
000858,3=A097,4=-1
000001,&A097&
000859,3=V098,4=1
000001,&V098&
000825
815
   End Options %3
   Declare %1
   1 - P
   Options %2
817,,LIST
814,3=PONT
805
806
825,2=DETA
805
806
808,4=0.180
000810
000858,7=0.000
000858,3=A099,4=-1
000001,&A099&
000859,3=V09A,4=1
000001,&V09A&
815
   End Options %3
   Rails
   Declare %1
   1 - RA
   Options %2
817,,LIST
814,3=RAIL
805
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A09B,4=-1
000001,&A09B&
000859,3=V09C,4=1
000001,&V09C&
815
   End Options %3
   Stiles
   Declare %1
   1 - STY
   Options %2
817,,LIST
814,3=STYL
805
810,MACR,2=STILESYM,8=-10.000,6=-3.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A09D,4=-1
000001,&A09D&
000859,3=V09E,4=1
000001,&V09E&
815
   End Options %3
   Shoulders
   Declare %1
   1 - S
   Options %2
817,,LIST
814,3=SHDR
805,1=9
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A09F,4=-1
000001,&A09F&
000859,3=V0A0,4=1
000001,&V0A0&
815
   End Options %3
   Declare %1
   1 - V
   Options %2
817,,LIST
814,3=VERG
805,1=9
810,MACR,2=VRGFPTRK,8=-12.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0A1,4=-1
000001,&A0A1&
000859,3=V0A2,4=1
000001,&V0A2&
815
   End Options %3
   Declare %1
   1 - WAL
   Options %2
817,,LIST
814,3=WALL
805,1=2
810,MACR,2=LOWWALLL,8=-5.000,6=-0.500
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0A3,4=-1
000001,&A0A3&
000859,3=V0A4,4=1
000001,&V0A4&
815
   End Options %3
   Declare %1
   1 - WAR
   Options %2
817,,LIST
814,3=WALL
805,1=2
810,MACR,2=LOWWALLR,8=-5.000,6=-0.500
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0A5,4=-1
000001,&A0A5&
000859,3=V0A6,4=1
000001,&V0A6&
815
   End Options %3
   Declare %1
   1 - WRL
   Options %2
817,,LIST
814,3=WALL
805,1=2
810,MACR,2=RETWALLL,8=-10.000,6=-1.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0A7,4=-1
000001,&A0A7&
000859,3=V0A8,4=1
000001,&V0A8&
815
   End Options %3
   Declare %1
   1 - WRR
   Options %2
817,,LIST
814,3=WALL
805,1=2
810,MACR,2=RETWALLR,8=-10.000,6=-1.000
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0A9,4=-1
000001,&A0A9&
000859,3=V0AA,4=1
000001,&V0AA&
815
   End Options %3
   Contours (Normal)
   Declare %1
   1 - Y
   Options %2
817,,LIST
814,3=CONN
805,1=7
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0AB,4=-1
000001,&A0AB&
000859,3=V0AC,4=1
000001,&V0AC&
815
   End Options %3
   Declare %1
   1 - Z
   Options %2
817,,LIST
814,3=CONI
805,1=8
810
825
805
806
808,4=0.180
000858,7=0.000
000858,3=A0AD,4=-1
000001,&A0AD&
000859,3=V0AE,4=1
000001,&V0AE&
815
   End Options %3
Through Alignment Design (TAD) style set used. "MXRAIL track 5001.3.pss" file contents:
   Style Set Created by version 1 of the Style Set Editor on the 02/10/2000
   Style Set Editor file: MXRAIL track 5001
000805,1=1,4=0.300
000806,1=1
000810
   Global Options End
   Start %0
   SandC Text                                        '*T  '          '    '         16384         ''    ''    '0'    'False'
   Cant Details                                      'C   '          '    '         2             ''    ''    '0'    'False'
   Track Centrelines (Geometry)                      'GC  '          '    '         4096          ''    ''    '0'    'False'
   SandC Centrelines (Geometry)                      'GT  '          '    '         4096          ''    ''    '0'    'False'
   SandC IP Lines (Geometry)                         'GU  '          '    '         4096          ''    ''    '0'    'False'
   Track Centre Lines                                'MC  '          '    '         64            ''    ''    '0'    'False'
   SandC Centre Lines                                'MT  '          '    '         64            ''    ''    '0'    'False'
   SandC IP Lines                                    'MU  '          '    '         64            ''    ''    '0'    'False'
   Rails                                             'R   '          '    '         2             ''    ''    '0'    'False'
   SandC IP Tick                                     'TI  '          '    '         2             ''    ''    '0'    'False'
   SandC Nose Tick                                   'TN  '          '    '         2             ''    ''    '0'    'False'
   SandC Toe Lines                                   'TT  '          '    '         2             ''    ''    '0'    'False'
   End %0
   SandC Text
   Declare %1
   1 - *T
   Options %2
817,,LIST
814,3=STXT
805,1=3,4=0.010
806,1=3
810
830,7=0.050
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A001,4=-1
000001,&A001&
000859,3=V002,4=1
000001,&V002&
815
   End Options %3
   Cant Details
   Declare %1
   1 - C
   Options %2
817,,LIST
814,3=CANT
805,1=1
810
806,1=1
808,4=0.180
000825
000858,2=D001
000858,3=A003,4=-1
000001,&A003&
000859,2=D002,7=0.000,10=0.000
000859,3=V004,4=-11
000001,&V004&
000860,4=0.100
000812,1=OFF
815
   End Options %3
   Declare %1
   1 - GC
   Options %2
817,,LIST
814,3=GEOM
805,1=3
810
806
808,4=0.180
809,1=HTPS,2=ONES,9=0.000
861,2=IADSYMB1,4=-1.000
000858,7=0.000
000858,3=A005,4=-1
000001,&A005&
000859,3=V006,4=1
000001,&V006&
000825
815
   End Options %3
   Declare %1
   1 - GT
   Options %2
817,,LIST
814,3=GEOM
805,1=3
810
806
808,4=0.180
000858,7=0.000
000858,3=A007,4=-1
000001,&A007&
000859,3=V008,4=1
000001,&V008&
000825
815
   End Options %3
   Declare %1
   1 - GU
   Options %2
817,,LIST
814,3=GEOM
805,1=2
810
806
808,4=0.180
000825
809,1=HIPS,2=ONES,9=0.000
000866,7=1.000
000869,4=-25
863,2=1,4=1.000
000812,1=OFF
815
   End Options %3
   Track Centre Lines
   Declare %1
   1 - MC
   Options %2
817,,LIST
814,3=MTRK
805,1=2,4=0.010
806,1=2
810
825,2=DETA,7=100.000
808,4=0.100,5=1,6=0.700
810
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A009,4=-1
000001,&A009&
000859,3=V00A,4=1
000001,&V00A&
815
   End Options %3
   SandC Centre Lines
   Declare %1
   1 - MT
   Options %2
817,,LIST
814,3=MTRK
805,1=2,4=0.010
810
825
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A00B,4=-1
000001,&A00B&
000859,3=V00C,4=1
000001,&V00C&
815
   End Options %3
   SandC IP Lines
   Declare %1
   1 - MU
   Options %2
817,,LIST
814,3=MAST
805,1=2
810
806,1=2
808,4=0.180
000825
000866,7=1.000,10=100.000
000869,4=-11
000860,4=0.100
000812,1=OFF
815
   End Options %3
   Rails
   Declare %1
   1 - R
   Options %2
817,,LIST
814,3=RAIL
805,1=6,4=0.010
810
825
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A00D,4=-1
000001,&A00D&
000859,3=V00E,4=1
000001,&V00E&
815
   End Options %3
   SandC IP Tick
   Declare %1
   1 - TI
   Options %2
817,,LIST
814,3=SIPT
805,1=6,4=0.010
810
825
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A00F,4=-1
000001,&A00F&
000859,3=V010,4=1
000001,&V010&
815
   End Options %3
   SandC Nose Tick
   Declare %1
   1 - TN
   Options %2
817,,LIST
814,3=SNST
805,1=6,4=0.010
810
825
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A011,4=-1
000001,&A011&
000859,3=V012,4=1
000001,&V012&
815
   End Options %3
   SandC Toe Lines
   Declare %1
   1 - TT
   Options %2
817,,LIST
814,3=STOE
805,1=6,4=0.010
810
825
805
806
808,4=0.180
810
000858,7=0.000
000858,3=A013,4=-1
000001,&A013&
000859,3=V014,4=1
000001,&V014&
815
   End Options %3
The "MXRAIL track 5001.3.pss" is used for both our TAD files, as well as for the actual designs produced. Is it possible to use the MX *.pss files in ORD, or is there some equivalent files that can be produced, or a conversion process? Currently, if I try to import a TAD GENIO file, for instance, it doesn't display the green "dumb-bells" as expected, instead displaying them as a series of points connected together. Here's how it should look when imported (in ORD those dumb-bells wouldn't be showing by default, instead creating random lines stretching across left, right and centre lines):
Any help would be much appreciated.
There is also the matter of the pre-set preferences file NR uses: "UK_metric.+prm" - is this something that is incorporated already in ORD, or is it something that can be added in?
* Version=08050000 	* Do not edit this line
* PARAMETER FILE
* THIS IS A DATA FILE WHICH HOLDS THE USER-CHANGEABLE SYSTEM DEFAULTS FOR
* MOSS.
* FILE FORMAT
*           A) ANY DATA FOLLOWING AN ASTERISK '*' IS DESIGNATED A COMMENT
*              AND IS IGNORED.
*           B) EACH LINE OF DATA MUST BEGIN WITH A KEYWORD, WHICH MUST CONTAIN
*              8 CHARACTERS AND BEGIN IN COLUMN 1.
*           C) A KEYWORD MUST BE IMMEDIATELY FOLLOWED BY AN EQUALS SIGN '='.
*              THERE MUST BE NO SPACES BETWEEN THE KEYWORD AND THE EQUALS SIGN.
*           D) THE EQUALS SIGN MUST BE IMMEDIATELY FOLLOWED BY THE VALUE TO BE
*              ASSIGNED TO THE SYSTEM PARAMETER. THERE MUST BE NO SPACES
*              BETWEEN THE EQUALS SIGN AND THE VALUE. THE VALUE CAN BE REAL,
*              INTEGER OR CHARACTER, BUT IT MUST BE OF THE SAME TYPE AS THE
*              EXISTING PARAMETER.
*           E) WHEN CHARACTER VALUES ARE USED THEY ARE ASSUMED TO BE 8
*              CHARACTERS IN LENGTH. IF THE VALUE IS SHORTER THAN 8 CHARACTERS
*              IT MUST BE PADDED OUT TO 8 CHARACTERS USING BLANKS.
*           F) FOR TRANSLATION PURPOSES. INSERT A * IN COLUMN 9 FOR EVERY 5 OR
*              SO LINES OF CONTINUOUS COMMENTS
* PARAMETERS FOR METRIC/IMPERIAL CONVERSIONS
* THESE PARAMETERS MUST PRECEDE ANY OTHER PARAMETERS WHICH ARE INPUT
* IN METRIC OR IMPERIAL DISTANCES
METR_IMP=1.0       * UNITS OF LINEAR MEASURE : 1.0=METRIC , 0.3048=IMPERIAL.
MET2IMP2=1.0       * IMPERIAL/METRIC CONVERSION FACTOR(USED IN DRAW)
*                       1.0 -METRIC
*                       2.54-IMPERIAL
*                       (CAN BE SET BY KODE18)
* SYSTEM PARAMETERS
LINEPAGE=60        * NUMBER OF LINES PER PAGE.
*                       MUST BE >  5
*                       OR        -1  TO TURN PAGING OFF
BANNEROP=1         * MOSS BANNER OUTPUT SWITCH
*                      0 - NO BANNER OUTPUT
*                      1 - BANNER OUTPUT (DEFAULT)
LGSWITCH=1         * LOGGING FILE SWITCH
*                      0 - NO LOG OF INPUT PRODUCED
*                      1 - LOG OF INPUT PRODUCED ON MOSSV92INP.LOG
LGIGSWCH=2         * LOGGING FILE SWITCH(IMOSS CURSOR HITS)
*                      1 - LOG OF INPUT PRODUCED ON MOSSV92IGM.LOG
*                      2 - LOG OF INPUT BUT NO ARCHIVE.
TRIAPRNT=1000      * MIN. NUMBER OF POINTS FOR TRIANGLE TRACE
*                    MUST BE >1
READINFO=00        * NUMBER OF TIMES README FILE MESSAGE IS INVOKED
MODELIST=2         * MODEL LIST SORT ORDER
*                      0 - AS STORED ON MODEL FILE
*                      1 - ALPHABETICAL SORT
*                      2 - DATE LAST USED IN REVERSE (DEFAULT)
* UNIT PARAMETERS
IN_ANGLE=0         * EXPECTED ANGULAR MEASURE INPUT UNITS.
*                       THIS VALUE CAN BE MODIFIED DURING EXECUTION WITH 017
*                       0 = DEG MIN SEC FOR MOST OPTIONS,DEG AND DEC FOR SOME
*                       1 = DEGREES MINUTES AND SECONDS THROUGHOUT
*                       2 = GRADS
*                       3 = DEGREES AND DECIMAL DEGREES
*                       4 = RADIANS
*                       5 = QUADRANT BEARINGS
OUT_ANGL=0         * EXPECTED ANGULAR MEASURE OUTPUT UNITS.
*                           (IF QUAD_BER=1 THEN BEARINGS ARE OUTPUT IN
*                                                        QUAD. BEARINGS)
*                       2 = GRADS
*                       4 = RADIANS
QUAD_BER=0         * INDICATOR FOR QUADRANT BEARING ANGULAR MEASURE OUTPUT.
*                       THIS VALUES CAN BE MODIFIED DURING EXECUTION WITH 017
*                       0 = NO QUADRANT BEARINGS REQUIRED
*                       1 = QUADRANT BERINGS REQUIRED
*                           (IF THIS IS SET TO 1 THEN SET OUT_ANGL = 1)
YXORD_IN=0         * INDICATOR FOR USA COORDINATE NOTATION FOR INPUT DATA.
*                       0 = BRITISH,DANISH AND CZECH2 NOTATION
*                       1 = USA,CZECH1,FAR EAST NOTATION
YXORDOUT=0         * INDICATOR FOR USA COORDINATE NOTATION FOR OUTPUT DATA.
*                       0 = BRITISH NOTATION  X/Y - EG. EASTING THEN NORTHING
*                       1 = USA NOTATION      Y/X _ EG. NORTHING THEN EASTING
*                       2 = DANISH NOTATION   Y/X _ EG. NORTHING THEN WESTING
*                       3 = CZECH1 NOTATION   X/Y _ EG. SOUTHING THEN WESTING
*                       4 = CZECH2 NOTATION   Y/X _ EG. WESTING THEN SOUTHING
*                       5 = FAR EAST NOTATION X/Y _ EG. NORTHING THEN EASTING
X_OSHIFT=0.0       * VALUE NEEDED TO BE ADDED TO NEGATIVE X COORDINATES
*                    TO ENSURE ALL POSITIVE VALUES INTERNALLY
*                    TYPICAL EXAMPLE 10000000.0
Y_OSHIFT=0.0       * VALUE NEEDED TO BE ADDED TO NEGATIVE Y COORDINATES
* ADDITIONAL OPTION 017 PARAMETERS
CURVEFIT=1         * CURVE FITTING INDICATOR
*                      0 - CURVE FITTING OFF
*                      1 - CURVE FITTING ON (DEFAULT)
TRIAECHO=0         * TRIANGLE ECHO ERROR
*                      0 - NO ECHO (DEFAULT)
*                      1 - NORMAL ECHO
*                      2 - DOUBLE ECHO
FLATTRIA=1         * ALLOW/BAN PRODUCTION OF FLAT TRIANGLES
*                      O - DISALLOW FLAT TRIANGLES
*                      1 - ALLOW FLAT TRIANGLES (DEFAULT)
NVOFFSET=0         * SELECT NORMAL OR VERTICAL OFFSETS WITHIN
*                    DESIGN OPTIONS THAT ALLOW NORMAL OFFSETS
*                      0 - USE VERTICAL OFFSETS
*                      1 - USE NORMAL OFFSETS
SSTATLAB=PSSA      * SURVEY STATION STRING LABEL
SINTTOLE=20.0      * SECONDARY INTERPOLATION TOLERANCE
POINTTOL=0.01      * POINT SEARCH TOLERANCE
SECTOFFL=-100.0    * LEFT SECTION OFFSET
SECTOFFR=100.0     * RIGHT SECTION OFFSET
BASEBEAR=0.0       * SECTION BASELINE BEARING
*                    (SEE IN_ANGLE FOR UNITS = DECIMAL DEGREES)
SINTOFFS=20.0      * SECONDARY INTERPOLATION OFFSET
* DESIGN PARAMETERS
AHDETOLR=0.100     * Default Chord-to-Arc tolerance
*                    The chord-to-arc tolerance parameter only affects the
*                     addition of points to the design / survey (202) ; it has NO
*                    effect on the drawing.
MRSWITCH=1         * RADIUS/M-VALUE SWITCH(USED IN VALGN)-FRENCH REQUIREMENT.
*                      0 - M-VALUE USED WITHIN VALGN
*                      1 - RADIUS USED WITHIN VALGN
*                      2 - K-VALUE USED WITHIN VALGN
RLADEFLT=0         * DEFAULT VALUE FOR TRANSITION USAGE (RL/A). USED IN
*                    HALGN AND DRAW.
*                      0 - RL
*                      1 - A
FDESWTCH=0         * FRENCH DESIGN 133 SWITCH - FRENCH REQUIREMENT.
*                      0 - DESIGN 133 USES ENGLISH RULES
*                      1 - DESIGN 133 USES FRENCH RULES
CUBIFACT=0         * METHOD OF CUBIC TRANSITION CURVE CALCULATION
*                      0 - WITHOUT FACTOR ADDED
*                      1 - WITH FACTOR ADDED AND ENHANCED CURVE TO
*                          CURVE CUBIC THEORY
*                      3 - WITH NSW FACTOR ADDED
*                      SEE USER MANUAL FOR DETAILS OF CUBIC FORMULA
CUBILENG=0         * INPUT DEFINITION CUBIC TRANSITION LENGTH
*                      0 - CURVE lENGTH
*                      1 - TANGENT lENGTH
*                          CUBIC TRANSITION LENGTH CALCULATION
TRANLENG=1         * INPUT DEFINITION CURVE TO CURVE SAME HAND
*                      TRANSITION LENGTH
*                      0 - SPECIFIED LENGTH TO TRANSITION ORIGIN
*                      1 - SPECIFIED LENGTH IS ACTUAL LENGTH
* PLOTTER PARAMETERS.
*PEN COLOURS REMOVED TO DRCOLOURS FILE
INIMV_X1=0.0       * THESE THREE VALUES DETERMINE THE INITIAL PEN MOVE.
INIMV_Y1=0.0       * THEY ARE USED THUS:    CALL PLOT(X1,Y1,3)
INIMV_Y2=0.0       *                     +  CALL PLOT(X1,Y2,-3)
*                    SET THE THREE VALUES TO 0.0 IF YOU DON'T WANT AN
*                    INITIAL PEN MOVE
*                    SET THE THREE VALUES AS FOLLOWS TO MOVE THE PEN
*                    TO RIGHT HAND SIDE FOR A DRUM PLOTTER
*                       INIMV_X1=10.0
*                       INIMV_Y1=-75.0
*                       INIMV_Y2=-70.0
ARSWITCH=0         * EXTENDED .PIC FILE FUNCTIONALLITY.
*                      0 - NOT EXTENDED
*                      1 - EXTENDED
PICOORDS=1.0       * UNITS IN WHICH COORDINATES ARE HELD ON THE PICTURE FILE.
*                      1.0       - CENTIMETRES.
*                      0.3937009 - INCHES.
CHARATIO=100       * CHARACTER WIDTH/HEIGHT RATIO*100. IF YOUR INSTALLATION'S
*                      SUBROUTINE SYMBOL ALLOWS TEXT TO BE CONTINUED WITH
*                      THE X=999.0,Y=999.0 FACILITY, USE VALUE -1.
* DRAW PARAMETERS.
DPAPORIN=1         *  SHEET ORIENTATION          : 1 = LANDSCAPE
*                                                : 2 = PORTRAIT
DPAPTYPE=0         *  PAPER TYPE (800)           : 0 = INTERACTIVE
*                                                : 1 = PLOTTER
DEFPAGLN=84.1      *  DEFAULT PAGE LENGTH (800)  : +VE REAL NO.
*                                                : (EG. 'A1' LENGTH = 84.1)
DEFPAGWD=59.4      *  DEFAULT PAGE WIDTH (800)   : +VE REAL NO.
*                                                : (EG. 'A1' WIDTH = 59.4)
DPAGMAXL=400.0     *  MAXIMUM ALLOWABLE PAGE     : +VE REAL NO. (INSTALLATION
*                      LENGTH (800)              : DEPENDENT)
DPAGMAXW=400.0     *  MAXIMUM ALLOWABLE PAGE     : +VE REAL NO. (INSTALLATION
*                      WIDTH (800)               : DEPENDENT)
DFACPLOX=1.0       *  X PLOT FACTOR (800)        : +VE REAL NO.
DFACPLOY=1.0       *  Y PLOT FACTOR (800)        : +VE REAL NO.
DMARSIZE=5.0       *  MARGIN SIZE (802)          : +VE REAL NO.
DPAGEING=0         * P AGEING (803)              : 0 = NO PAGEING
*                                                : 1 = PAGEING
DATRUNCN=1         *  TRUNCATION (803)           : 0 = NO TRUNCATION
*                                                : 1 = TRUNCATION
DPENCOLR=1         *  PEN COLOUR (805 AND 806)   : 1 = BLACK
*                                                : 2 = RED
*                                                : 3 = GREEN
*                                                : 4 = BLUE
*                                                : 5 = CYAN
*                                                : 6 = YELLOW
*                                                : 7 = ORANGE
*                                                : 8 = PINK
*                                                : 9 = GREY
*                                                : 10= PALEBLUE
*                                                : (INSTALLATION DEPENDENT,
*                                                :  IN DRCOLOURS.DAT)
DCHRTYPE=N         *  CHARACTER TYPE (808)       : N = NO CONVERSION
*                                                : L = ALL CHARACTERS LOWERCASE
*                                                :      (MACHINE DEPENDENT)
*                                                : U = ALL CHARACTERS UPPERCASE
DCHARHYT=0.18      *  CHARACTER HEIGHT (808)     : +VE REAL NO.
DNUMDECP=3         *  NO. OF DECIMAL PLACES (808): +VE INTEGER NO.
DCHRATIO=1.0       *  CHARACTER ASPECT RATIO     : +VE REAL NO. (GKS MACHINE
*                      (WIDTH/HEIGHT) (808)      : DEPENDENT)
DCHARSPC=0.0       *  CHARACTER SPACING (808)    : +VE REAL NO. (GKS MACHINE
*                                                : DEPENDENT)
DLINSPAC=0.5       *  LINE SPACING INTERVAL      : +VE REAL NO. RELATED TO
*                      FOR TEXT (808)            : CHARACTER HEIGHT
*                      RATIO OF CH. HT.
DFONTYPE=          *  DEFAULT FONT NAME (808)    :      = USE H/W FONT
*                                                : SOF1 = DEFAULT S/W FONT1.MFF
*                                                : SOFn = USER S/W FONT n
*                                                         FONT2.MFF to
*                                                         FONT9.MFF
DFRAMTYP=0         *  FRAME TYPE (821)           : 0 = NO FRAME
*                                                : 1 = FRAME
*                                                : 2 = WINDOW
*                                                : 3 = REGISTRATION MARKS
DGRDTIKX=1.0       *  GRID X TICK SIZE (822)     : +VE REAL NO.
DGRDTIKY=1.0       *  GRID Y TICK SIZE (822)     : +VE REAL NO.
DINTSEQP=1         *  POINT SEQUENCE NUMBER      : +VE INTEGER NO.
*                      INTERVAL (825)            :
DLABTYPE=0         *  LABELS (825 AND 826)       : 0 = NO LABEL
*                                                : 1 = LABEL
DPIPLENG=0.1       *  PIP LENGTH (825 AND 860)   : +VE REAL NO.
DSYMLENG=1.0       *  STANDARD SYMBOL LENGTH AS  : +VE REAL NO.
*                      A PROPORTION OF CURRENT   :
*                      CHARACTER SIZE (825(DETA)):
DCHMAINT=100.0     *  CHAINAGE MARKING INTERVAL  : +VE REAL NO.
*                      (826,866,867)             :
DOFFSEQP=0.5       *  TEXT OFFSET OF POINT       : REAL NO.
*                      SEQUENCE NUMBER (PSN)(865):
DPSNMINT=1         *  PSN MARKING INTERVAL (865) : +VE INTEGER NO.
DCHAMPIP=0.1       *  CHAINAGE MARKING PIP       : +VE REAL NO.
*                      SIZE (866)                :
DCHAMOFF=0.5       *  CHAINAGE MARKING TEXT      : REAL NO.
*                      OFFSET (866)              :
DCHAMAPI=0.1       *  CHAINAGE-BOTH-SIDE-MARKING : +VE REAL NO.
*                      PIP SIZE (867)            :
DCHAMAOF=-0.5      *  CHAINAGE-BOTH-SIDE-MARKING : REAL NO.
*                      TEXT OFFSET (867)         :
DSPOTLEV=0.5       *  SPOT LEVEL TEXT            : REAL NO.
*                      OFFSET (868)              :
DSTRAOFF=0.5       *  STRING DIMENSION ANNOTATION: REAL NO.
*                      TEXT OFFSET (869)         :
DHATANGL=0.0       *  HATCHING ANGLE (DEGREES)   : REAL NO.
*                      (875,877,879,891,892,893) :
DHATSPAC=0.25      *  HATCH SPACING (CMS)        : REAL NO.
DGRADTYP=0         *  GRADIENT IN PERCENT  = 0   : INTEGER NO.
*                                 PERMILLE = 1   :
*                      (864,7=-23)
*                      THIS SWITCH WILL ONLY OPERATE IF PERCENT HAS
*                      BEEN REQUESTED ON OPTION 809 OR SET BY
*                      THE KEYWORD XFCANDEF (BELOW)
DCLOTHTY=0         *  CLOTHOID ANNOTATION        : INTEGER NO.
*                       CL = 0
*                       RP = 1
*                      (869,4=-25)
DRDSCALE=1000.0    *  DEFAULT DRAWING SCALE      : REAL NO.
*                      (803)
DINFISYM=1         *  MACRO SYMBOL SWITCH FOR INFINITY RADII
*                        0 - PRINT OUT "INFINITY"
*                        1 - USE MACRO SYMBOL
DREALINT=0         *  SWITCH TO DETERMINE WHETHER PARTIAL DISTANCES
*                     ARE CALCULATED USING REAL OR INTERPOLATED POINTS
*                     ON A PAGED DRAWING
*                        0 - USE REAL POINTS
*                        1 - USE INTERPOLATED POINTS
DGSTGCOD=1         *  GEOMETRY STRING CODES       :INTEGER NO.
*                         VALID CODES:
*                       1. HTPS - HORIZONTAL TANGENT POINTS
*                       2. HIPS - HORIZONTAL INTERSECTION POINTS
*                       3. HCEN - HORIZONTAL ARC CENTRES
*                       4. VTPS - VERTICAL TANGENT POINTS
*                       5. VIPS - VERTICAL INTERSECTION POINTS
*                       6. VFPS - VERTICAL FLAT POINTS
*                       7. VMOS - VERTICAL MID-ORDINATE POINTS
*                       8. SUPE - SUPERELEVATION ANNOTATION
XFCANDEF=11        *  SUPERELEVATION UNITS
*                     (809,field 4)
*                     This value is interpreted as two columns.
*                     10's column :
*                     CROSSFALL UNITS          1* = PERCENT
*                                              2* = DECIMAL PERCENT
*                                              3* = 1:N
*                     units value if metric :
*                     CANT UNITS (METRIC)      *1 = METRES
*                                              *2 = CENTIMETRES
*                                              *3 = MILLIMETRES
*                     units value if imperial :
*                     CANT UNITS (IMPERIAL)    *1 = DECIMAL FEET
*                                              *2 = DECIMAL INCHES
CLUTTEXT=1         *  CLUTTERED TEXT SWITCH
*                        0 - DO NOT REMOVE CLUTTERED TEXT
*                        1 - REMOVE CLUTTERED TEXT
* GEOMETRY STRING ANNOTATION
* Draw minor option 869 allows you to output Horizontal and Vertical
* Tangent point data start/end labels
* The default start/end labels are shown for Horizontal and Vertical
* between - and =, the definition of the label is shown after the *.
* To change the label appended to the drawing using DRAW minor option
* 869 field 4=-46;
* Enter after the = strt and end labels
* Examples
*       ABCD/ABCD gives start label ABCD and end label ABCD
*       ABCD/EFGH gives start label ABCD and end label EFGH
*       /EFGH gives end label EFGH only
*       ABCD/ gives start label ABCD only
* Notes
* If between = and * is blank, the code between - and = is used.
* A maximum of 4 characters are permitted either side of the /.
* THE CODES ARE UNNECESSARY FOR BRITISH ANNOTATION AND HAVE
* THEREFORE BEEN COMMENTED OUT IN THE FOLLOWING LINES
* IF THE SPECIAL ANNOTATION IS REQUIRED - REMOVE THE
* ASTERISK AND SPACE IN FRONT OF EACH LINE COMMENCING
* WITH GEH OR GEV BELOW.
* HORIZONTAL             ELEMENT BEFORE        CODE    ELEMENT AFTER
* GEH-PBT =/GA       *         NONE              PBT      STRAIGHT
* GEH-PBC =/BA       *         NONE              PBC      ARC
* GEH-PAT =GE/       *         STRAIGHT          PAT      NONE
* GEH-PAC =BE/       *         ARC               PAC      NONE
* GEH-TS  =GE/UA     *         STRAIGHT          TS       SPIRAL
* GEH-ST  =UE/GA     *         SPIRAL            ST       STRAIGHT
* GEH-CS  =BE/UA     *         ARC               CS       SPIRAL
* GEH-SC  =UE/BA     *         SPIRAL            SC       ARC
* GEH-SS  =UE/UA     *         SPIRAL            SS       SPIRAL
* GEH-PC  =GE/BA     *         STRAIGHT          PC       ARC
* GEH-PT  =BE/GA     *         ARC               PT       STRAIGHT
* GEH-PRC =BE/BA     *         ARC               PRC      ARC
* GEH-PCC =BE/BA     *         ARC               PCC      ARC
* VERTICAL               ELEMENT BEFORE        CODE    ELEMENT AFTER
* GEV-PBT =/GA       *         NONE              PBT      GRADE
* GEV-PBC =/BA       *         NONE              PBC      CURVE
* GEV-PAT =GE/       *         GRADE             PAT      NONE
* GEV-PAC =GA/       *         CURVE             PAC      NONE
* GEV-PT  =BE/GA     *         CURVE             PT       GRADE
* GEV-PC  =GE/BA     *         GRADE             PC       CURVE
* GEV-TT  =GE/GA     *         GRADE             TT       GRADE
* GEV-VX  =BE/BA     *         CURVE             VX       CURVE
*       *            *             Curve high or low point
* GEV-VM  =BE/BA     *         CURVE             VM       CURVE
*                    *             Curve middle ordinate point
* GEV-PCC =BE/BA     *         CURVE             PCC      CURVE
*                    *             Curve same sense
* GEV-PRC =BE/BA     *         CURVE             PRC      CURVE
*                    *             Curve opposite sense
* GEV-VMX =BE/BA     *         CURVE             VMX      CURVE
*       *            *             Curve coincident high or low
*                    *             and middle ordinate point
* STANDARD/CURVED INTERFACE PARAMETERS
GRADINTR=0.667     * DEFAULT GRADIENT FOR STANDARD/CURVED INTERFACE
TANGINTR=3.0       * DEFAULT TANGENT LENGTH FOR STANDARD/CURVED INTERFACE
WDTHINTR=2.0       * DEFAULT DITCH WIDTH FOR STANDARD/CURVED INTERFACE
DPTHINTR=0.3       * DEFAULT DITCH DEPTH FOR STANDARD/CURVED INTERFACE
* ALIGNMENT PARAMETERS
* HORIZONTAL DISPLAY
*   Available colours                   Available line styles
*     1 --- Black                           1 --- Solid
*     2 --- Red                             2 --- Dashed
*     3 --- Green                           3 -- Dotted
*     4 --- Blue                            4 -- Dot/dash
*     5 --- Cyan
*     6 --- Yellow
*     7 --- Orange
*     8 --- Pink
*     9 --- Grey
*     10--- Paleblue
AHDIBGDC=5         * Background colour
AHDIBGDS=1         * Background style
AHDISGDC=5         * Spline Background colour
AHDISGDS=1         * Spline Background style
AHDIELEC=6         * Element colour/working colour
AHDIELES=1         * Element style/working style
AHDISLEC=6         * Spline element colour/working colour (splines)
AHDISLES=1         * Spline element style/working style (splines)
AHDISTRC=5         * Straights colour
AHDISTRS=1         * Straights style
AHDIARCC=3         * Arcs colour
AHDIARCS=1         * Arcs style
AHDITRNC=6         * Trans colour
AHDITRNS=1         * Trans style
AHDIDIRA=1         * Direction arrows        1 --- Drawn
*                                            2 --- Not drawn
AHDITPTM=1         * Tangent point markers   1 --- Drawn
*                                            2 --- Not drawn
AHDITXAN=1         * Auto annotation switch  1 --- Yes
*                                            2 --- No
* HORIZONTAL DESIGN
* The chord-to-arc tolerance is held in AHDETOLR under the DESIGN
* parameters.
AHDEDESP=120.000   * Design speed
AHDEMINR=250.000   * Minimum radius for spline alignments
AHDERCLA=0.300     * Maximum RCLA
AHDEDESM=1         * Design methods       1 --- Element
*                                         2 --- I.P.
*                                         3 --- Spline
AHDERADU=1         *                      1 --- Radius
*                                         2 --- DOC (A)
*                                         3 --- DOC (C)
AHDECRVI=1         * Curve intersection methods (I.P. only )
*                                         1 --- 3IPS
*                                         2 --- ALL IPS
AHDETRNR=1         * Transition rules     1 --- None
*                                         2 --- French roads
*                                         3 --- Dutch rail
*                                         4 --- German rail
AHDETRNF=6         * Transition formulae  1 --- Clothoid
*                                         2 --- Bloss
*                                         3 --- Cubic
*                                         4 --- Bi-quadratic
*                                         5 --- Sine
*                                         6 --- Notrans
AHDECDBY=6         * Clothoid defined by
*                                         1 --- Rules
*                                         2 --- N/A
*                                         3 --- A value
*                                         4 --- RL value
*                                         5 --- Speed
*                                         6 --- Length
AHDECOBY=2         * Clothoid overriden by
*                                         1 --- N/A
*                                         2 --- Length
*                                         3 --- RL value
*                                         4 --- A value
*                                         5 --- Speed
AHDEC__A=400.000   * Clothoid defined by A value
AHDEC_RL=114590.0  * Clothoid defined by RL value
AHDEC_SP=100.000   * Clothoid defined by SPEED
* DUTCH TRANSITION
AHDTDESS=0.000     * Design speed
AHDTDEFF=0         * Default deficiency factor
AHDTGRDT=1         * Default gradient type
*                                          1 --- 1:10V
*                                          2 --- 1:8V
AHDTMITC=20.000    * Minimum theoretical crossfall
AHDTMATC=270.000   * Maximum theoretical crossfall
AHDTMAAC=150.000   * Maximum allowable crossfall
* FRENCH TRANSITION
AHFTDESS=1         * Design speed         1 --- 40
*                                         2 --- 60
*                                         3 --- 80
*                                         4 --- 100
*                                         5 --- 120
AHFTNOLA=1         * Number of lanes      1 --- 2
*                                         2 --- 3
*                                         3 --- 4
AHFTRDCL=1         * Road classification  1 --- AR
*                                         2 --- RP
*                                         3 --- UR
* VERTICAL DISPLAY
*     3 --- Green                           3 --- Dotted
*     4 --- Blue                            4 --- Dot/dash
*     5 --- Cyan
*     6 --- Yellow
*     7 --- Orange
*     8 --- Pink
*     9 --- Grey
*     10--- Paleblue
AVDIBGDC=5         * Background colour
AVDIBGDS=1         * Background style
AVDISGDC=5         * Spline Background colour
AVDISGDS=1         * Spline Background style
AVDIELEC=6         * Element colour/working colour
AVDIELES=1         * Element style/working style
AVDISLEC=6         * Spline element colour/working colour
AVDISLES=1         * Spline element style/working style
AVDIGRDC=5         * Grades colour
AVDIGRDS=1         * Grades style
AVDIHOGC=2         * Hog curves colour
AVDIHOGS=1         * Hog curves style
AVDISAGC=3         * Sag curve colour
AVDISAGS=1         * Sag curve style
AVDIVTPS=1         * Vertical T.P's
AVDIDIRM=1         * Direction markers    1 --- Drawn
*                                         2 --- Not drawn
AVDIHTPS=1         * Horizontal T.P's     1 --- Drawn
*                                         2 --- Not drawn
AVDIVERM=1         * Vertex markers       1 --- Drawn
*                                         2 --- Not drawn
AVDITXAN=1         * Auto annotation switch  1 --- Yes
*                                            2 --- No
* VERTICAL DESIGN
AVDEDESM=4         * Design method        4 --- Element
*                                         5 --- IP
*                                         6 --- Spline
AVDECURP=2         * Curve parameter      1 --- M-value
*                                         2 --- Radius
*                                         3 --- K-value
AVDECUIM=1         * Curve intersection method (I.P. only)
*                                         1 --- 3-IPS
*                                         2 --- ALL IPS
AVDEEMHG=0.000     * Extreme M value, hog
AVDEEMSG=0.000     * Extreme M value, sag
AVDEERHG=0.000     * Extreme radius, hog
AVDEERSG=0.000     * Extreme radius, sag
AVDEEKHG=0.000     * Extreme K value, hog
AVDEEKSG=0.000     * Extreme K value, sag
AVDEMAGD=0.000     * Maximum gradient
AVDEMIGD=0.000     * Minimum gradient
AVDEDMHG=10.000    * Default M value, hog
AVDEDMSG=10.000    * Default M value, sag
AVDEDRHG=1000.0    * Default radius, hog
AVDEDRSG=1000.0    * Default radius, sag
AVDEDKHG=10.000    * Default K value, hog
AVDEDKSG=10.000    * Default K value, sag
AVDEMICL=0.000     * Minimum curve length
AVDEDLHG=100.000   * Default length, hog
AVDEDLSG=100.000   * Default length, sag
AVDEKVAL=1         * K value              1 --- UK
*                                         2 --- AASHTO
AVDEDESS=120       * Design speed
AVDECREC=2         * Crest criterion
*                                         1 --- Overtake
*                                         2 --- Desmin
*                                         3 --- Absmin
* SUPERELEVATION PARAMETERS
* SUPERELEVATION DISPLAY
SUPCOLOR=2         * Superelevation applied colour
*                    See HORIZONTAL DISPLAY for available
*                    colours
* SUPERELEVATION DESIGN
SUPAPPLI=1         * Application              0 --- None
*                                             1 --- Crossfall
*                                             2 --- Cant
* CROSSFALL PARAMETERS
CROSUNIT=2         * Crossfall units          1 --- Percent
*                                             2 --- Decimal
*                                                   percent
*                                             3 --- 1 : N
CROSTHEO=0         * Theoretical Crossfall    0 --- Not applied
*                                             1 --- Applied
CROSFACT=2.828     *Theoretical Crossfall factor
CROSROUN=1         * Rounding for crossfall   1 --- Nearest
*                                             2 --- Up
*                                             3 --- Down
CROSTLPC=0.5       * Round up, down or to the nearest
*                    (percent)
CROSTLDC=0.005     * Round up, down or to the nearest
*                    (decimal percent)
CROSTL1N=20.0      * Round up, down or to the nearest (1:N)
CROSMNPC=2.5       * Minimum crossfall (percent)
CROSMNDC=0.025     * Minimum crossfall (decimal percent)
CROSMN1N=40.0      * Minimum crossfall (1:N)
CROSMXPC=7.0       * Maximum crossfall (percent)
CROSMXDC=0.07      * Maximum crossfall (decimal percent)
CROSMX1N=15.0      * Maximum crossfall (1:N)
CROSINPC=2.5       * Inflection crossfall (percent)
CROSINDC=0.025     * Inflection crossfall (decimal percent)
CROSIN1N=40.0      * Inflection crossfall (1:N)
* CANT PARAMETERS
CANTUNMT=1         * Cant units (metric)   1 --- mms
*                                          2 --- cms
*                                          3 --- metres
CANTUNIM=1         * Cant units (Imperial) 1 --- inches
*                                          2 --- feet
CANTTHEO=0         * Theoretical Cant      0 --- Not applied
*                                          1 --- Applied
CANTFACT=0.085     * Theoretical Cant factor
CANTROUN=1         * Rounding for cant     1 --- Nearest
*                                          2 --- Up
*                                          3 --- Down
CANTTLMM=5.0       * Round up, down or to the nearest (mm)
CANTTLCM=0.5       * Round up, down or to the nearest (cm)
CANTTLMT=0.05      * Round up, down or to the nearest (metre)
CANTTLIN=0.5       * Round up, down or to the nearest (inch)
CANTTLFT=0.042     * Round up, down or to the nearest (foot)
CANTMNMM=0.0       * Minimum cant (mm)
CANTMNCM=0.0       * Minimum cant (cm)
CANTMNMT=0.0       * Minimum cant (metre)
CANTMNIN=0.0       * Minimum cant (inch)
CANTMNFT=0.0       * Minimum cant (foot)
CANTMXMM=150.0     * Maximum cant (mm)
CANTMXCM=15.0      * Maximum cant (cm)
CANTMXMT=0.15      * Maximum cant (metre)
CANTMXIN=6.0       * Maximum cant (inch)
CANTMXFT=0.5       * Maximum cant (foot)
CANTINMM=0.0       * Inflection cant (mm)
CANTINCM=0.0       * Inflection cant (cm)
CANTINMT=0.0       * Inflection cant (metre)
CANTININ=0.0       * Inflection cant (inch)
CANTINFT=0.0       * Inflection cant (foot)
* END OF SUPERELEVATION PARAMETERS
* CREATE M-STRING PARAMETERS
CRMCHINT=10.0      * Chainage interval
CRMDRAWM=1         * Draw master string 1 = Yes
*                                       0 = No
* END OF CREATE M-STRING PARAMETERS
* Railway params:
TOGLCON1=1         * component library
*                  * 1=Type 1
*                  * 2=Type 2
RAILGAUG=1435.0    * STANDARD RAIL GAUGE PARAMETER (millimeters)
* PARAMETERS FOR 3 CENTRE CURVES
TCCANG01=15.75     * SUBTENDED ANGLE OF ARC 1.
TCCANG03=20.25     * SUBTENDED ANGLE OF ARC 3.
TCCRAT01=2.0       * RATIO OF RADIUS OF ARC 1 TO RADIUS OF ARC 2
TCCRAT03=3.0       * RATIO OF RADIUS OF ARC 3 TO RADIUS OF ARC 2
* PARAMETERS FOR ITALIAN 3 CENTRE CURVES
TCCANC  =0.6       * MAX LATERAL ACCELERATION
TCCANCD =0.6       * MAX LATERAL ACCELERATION (FREIGHT COMPONENT)
TCCC    =0.15      * RATE OF CHANGE OF LATERAL ACCELERATION
TCCI01  =0.2       * CANT GRADIENT (V>75)
TCCI02  =0.15      * CANT GRADIENT (75<V<=100)
TCCI03  =0.1       * CANT GRADIENT (100<V<=125)
TCCI04  =0.1       * CANT GRADIENT (125<V<=160)
TCCVELO =155.0     * ITALIAN DESIGN SPEED
* DRAINAGE PARAMETERS
DRAIPROG=4         * Default program  1 --- Wallrus
*                                     2 --- MicroRAT
*                                     3 --- MicroDrainage Windes Version 5
*                                     4 --- MicroDrainage Windes Version 6/7
DRAIMEAS=2         * Default measurement method 1 --- edge to edge
*                                               2 --- centre to centre
DRAIRETP=1         * Global variable 1 - Return period (years-max=99)
DRAILOCA=1         * Global variable 2 - Location (1=Eng&Wales)
DRAIM560=15        * Global variable 5 - M5-60 (mm)
DRAIRATI=0.5       * Global variable 6 - Ratio
DRAIMXRF=20        * Global variable 8 - Maximum rainfall (mm)
DRAIGTOE=5         * Global variable 13- Global time of entry (mins)
PROXCHCK=1         * Manhole and branch proximity check with carriageway
*                    1 = on
*                    2 = off
PIPEDIST=1.0       * Minimum distance for pipe proximity check
PIPESIZE=0.15      * Nominal pipe size for pipe proximity check (diameter m)
MANHDIST=0.5       * Minimum distance for manhole proximity check
DEFMASK1=C         * Default mask 1 to be included in mask for proximity check
DEFMASK2=C         * Default mask 2 to be included in mask for proximity check
DEFMASK3=C         * Default mask 3 to be included in mask for proximity check
DEFMASK4=C         * Default mask 4 to be included in mask for proximity check
*                    The above masks can only be 4 characters long and must be
*                    the first 4 characters after the = sign
LNGTCHCK=1         * Drainage length checking as manholes are linked
*                    1 = on
*                    2 = off
LNGTDIST=100.0     * Maximum distance for drainage pipe length checking
* IGMACRO COLOURS
*   Available colours
*     1 --- Black
*     2 --- Red
*     3 --- Green
*     4 --- Blue
*     5 --- Cyan
*     6 --- Yellow
*     7 --- Orange
*     8 --- Pink
*     9 --- Grey
*     10--- Paleblue
MACMESH1=5         * Mesh 1 colour
MACMESH2=4         * Mesh 2 colour
MACORIGN=2         * Origin colour
MACPDPER=3         * Pen Down permiable line colour
MACPDIMP=6         * Pen Down impermiable line colour
MACPUIMP=1         * Pen up impermiable line colour
* COMPRESS FLAG
COMPRESS=0         * During COMPRESS create archive file as
*                    0 = Temporary file
*                    1 = Permanent file
SKEWSECT=0         * set skew section flag
KINKBLOC=0         * set kink block flag
*Survey Parameters
CURVCORR=0                 *  Curvature correction                 : 0 = Curvature correction  OFF
*                           (Survey minor option 200 field 8)      : 1 = Curvature correction  ON
*Working v Final Drawing Parameter
MXAPPDRG=0                 *  0 = Use working drawings
*                             1 = Use final drawings
*SWITCH TO DETERMINE WHETHER TO INTERPOLATE OR PUT A DISCONTINUITY WHERE NO INTERFACE IS FOUND
INTERDIS=0                 *  0 - IF THERE IS NO INTERFACE FOUND
*                                 AT A SECTION THEN INTERPOLATE BETWEEN THE SECTIONS
*                             1 - IF THERE IS NO INTERFACE FOUND
*                                 PUT A DISCNTINUITY BETWEEN THE SECTIONS
STRINGNC=0                 *  0 - String Naming Convention will not be enabled
*                                  when a new project is created
*                             1 - String Naming Convention will be enabled
FINI
  • Hi Adam,
    As per annotation capabilities (PSS), nothing can be imported from MX to OpenRail. It is totally new, with new technology.
    Only OpenRail feature definitions (a kind of MX string styles) can be created from PSS by using MX SS4. Through Project Explorer you can import PSS to create feature defintions. You must do this in a dgnlib. Then, this dgnlib can be upgraded to OpenRail Designer.
    Then you will have to complete the feature definitions in the DGNLIB to get the same you had in MX.
    Basically, Feature Definitions are using feature symbologies that are using element templates that are using levels. Feature symbologies are also using Annotation group to produce different types of annotations.
    Annotations are using Text Favorites. If you don't know anything about text favorites, then it is probably the main thing you will have to become familiar with. Evrything else is quite basic.
    The best is to have a look on delivered workspaces and on learning content about OpenRoads workspaces.
    https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=111346
    You don't have thousands of styles so you can start creating from scratch at least for design style.
    Look into C:\ProgramData\Bentley\OpenRail Designer CE\Configuration\Organization-Civil\_Civil Default Standards - Metric\Dgnlib\Feature Definitions to do the same in a workspace or workset so that it will be automatically loaded when using this workspace or workset.
    File names include words to indicate what is being loaded. Example *feature*.dgnlib or *Elem Tem*.dgnlib
    Almost everything is configured through DGNLIbs set through workspace/workset (configuration files and folders).
    Most of parameters (prm) are by default set in "C:\ProgramData\Bentley\OpenRoads Designer CE\Configuration\Organization-Civil\_Civil Default Standards - Metric.cfg" or in File>Settings>File>DesignFile Settings
  • Hi. Thanks for the reply. Would we be able to get a quote for someone to do this conversion for us? Otherwise, NR will end up with the same confusing situation it had when BRT was rolled out. MX came with the standard parameter file and these style sets, but BRT was so messy that different teams had so many variations on dgnlibs that it was a disaster. If an expert in your company is able to take the files I've posted above and convert them through whatever process necessary to make something that works with OpenRail, it would be ideal. That's our main starting point, and then we can move forward with testing ORD properly.
  • Yes there are some typical plans to do upgrade from MX/INROADS/GEOPAK to OpenRoads/OpenRail.
    You should talk with yiour bentley sales contact.
    I know Robert Nice is actually developing workspace for UK.
    Could you send me pss/fns for the track I can have a look ?
    For detailed survey, we don't have anymore to display data from a model (database) but we are using the graphics instead (DGN/DWG). So it is a matter of receiving the good representation then usually we are using a graphical filter to create the terrain model from the graphics.
  • Hi - thanks for the offer. I can't seem to upload files via private message. Can I email them to you, please?
  • Yes please, email to jp.laville-noel@bentley.com
