Just installed OpenRail Designer 2020 Release 1, but missing a lot of stuff for our centenary guys, like "Create Structures"
When can we expect this, or will this be in OpenRail Overhead line Designer and when can we expect this version, because we need to move forward!
See also my question in the OpenRoads forum: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/191613/2019-r3-when
Regards, Christiaan
Hi Christaan;
This tool is currently at an early development phase and available only as key in. Can you reach me from my mail below so I can share with you the full details?
kivanc.karakas@bentley.com
Hi Kivanc, I get a mail from Ian so we know the key-inn. thanks.
//Christiaan
Are the keyins available to all Bentley clients or only those part of a testing program?I have OR 2020 R1 installed, but I can't use any of the tools. I get an error when i click on any Overhead Line tool.
It looks to be related to the workspace/workset and access to OHL design rules. If you don't use example workspace check *OVERHEADLINE* variables from settings>Configuration>Variables
I did. Created all three variables and pointed them to sample files in the Program Files or ProgramData folders.
OVERHEADLINE_DESIGNRULES_FILE
C:\ProgramData\Bentley\CONNECT Edition\Configuration\Organization-Civil\_Civil Default Standards - Metric\Overheadline\MetricOHLStandards.odr
OVERHEADLINE_DESIGNRULES_FOLDER
OVERHEADLINE_DESIGNRULES_SCHEMALOCATION
C:\Program Files\Bentley\OpenRail Designer\OpenRailDesigner\OverheadLine\XmlData\Schemas\DesignRuleDoc.xsd
It still doesn't work.
