I have a question about my OpenRail. My version is 10.08.00.88.
How to create a new turnout? As I saw, one way to solve this is copy from Standards Libraries any turnout and change different values for "my turnout". How to do it? If I try do this opening DGNLIB file (from _civil Default Standards - Metric), but I can't see turnout geometry in properties what I can edit. (screen 1 - on right side it's a screen from Bentley Page and there we can see Turnout geometry (lenght, ratio...) ).
What am I doing wrong? Please help.
cheers
AM
jpln
I have one more problem to solve with this turnouts. It is the same with turnouts from default library and created by me. For instance I put from Turnouts-German e4950012, what means, that it should has features:
Lenght (centerline) : 41.5946 m
Ratio : 12.000
Radius : 500m etc.
When I put this on my alignment, in properties I can see the correct features, but when I check the Radius, Lenght in graphic, I don't know, that Radius is now 481.13160m and the lenght along mainline is 40.99997m, what is incorrect.
I have working units in meters. Can you solve this problem?
regards
Probably an issue with geometry definition. Not accurate enough and/or does not fit. You can send your dgn and description of the turnout you want to create. I can have a look.
