I'm producing an model for a project of which no drawings are be producing and everything is going into a BIM environment.
I have included extra meta data into my models by adding items. Does anyone know if there is a way to get an excell output from the "ïtems" ? acutally if i could do a report from which would include everything in the propeties box it would cover what i'm trying to do?
Bryce
Hi Bryce,
The Item Type Instance Export will export all the attached Item Type info in the current model and associated element ID - maybe you tried Item Type Defintion Export?
We use this to get BIM data into Navisworks using the excel output in Data Tools.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Awesome this is great , Think I'm going to have some happy BIM people today
