Drawing production and workspace issues
I'm having issues regarding Drawing production and how to import our company standards to it when adding this to our Workspace.
For example which file is controlling these names...
Also I've tried to rename the input in the original files form "_Civil Default Standards - Metric" but is doesn't show up either whatever I change to the name.
I used the movies on the learn server as my start-point but no success yet.
Can someone point me in the right direction?
//Christiaan
  • The names are defined in the dgnlib (plan or cross section). The start seed is just there to be manually copied when creating a new dgnlib and to speed up creating new sheet definitions. It is not used by OpenRail.
    The names you have to select from the list are the name of the Saved Views created in the dgnlib.
    So if you want to change the name, edit the dgnlib and rename the saved view.
    Named boundaries are linked to Saved Views.
    When you create a named boundary (basically a clipping shape), a saved view is also created and linked to the named boundary. It also includes links to drawing and sheet models.
    Answer Verified By: Christiaan Post
