https://communities.bentley.com/products/rail_design/f/openrail-forum/201383/migration-utilities-failed-openrail-r2-update-8-10-08-01-33
Thank you for your feedback.
I would suggest to fill an enhancement request / defect so that we can amend the existing dgnlib and deliver something better.
However, as far as I know, there is no certification from the regulation authority.
For the KRS 1:4.5 it needs investigation to check what is going wrong and fill a defect if necessary. I will have a look.
Thanks for you're reaction JP
My colleague will make an enhancement reguest / defect report. Somehow this is not visible in my connection client.
Also succes with the investigation towards the KRS type turnouts.
PS just an other question about OpenRail that you maybe can answer.
Is in the latest version of OpenRail release 3 the export off the alignment to an XML-file fixed so that in the XML-file the horizontal/vertical design and the speed and the cant is included. I know this is an issue in release 1 of OpenRail that the xml-file did not have the cant and speed in the XML-file.
Sorry I missed this last post. yes 2020 R3 XML export (2.0) includes cant. Speed is part of cant.
By the way, unfortunately Diamonds are still wrong in 2020 R3, not only NL. A defect is logged and I highlighted it to product manager.
I do not know why Bentley does not develop a standard library of turnout for each country where they selling the product. These shall be accessible in the common library.
At least right or wrong some turnout is available. In other countries like UK/India/Singapore/Malaysia/USA and other countries, no turnout/Crossing library provided by Bentley. These shall be provided in the common Library.
