When adding a clipping plane to my corridor the 3D model gets a strange result?
When delete the clipping it looks fine again?
Does someone has the same experience?
//christiaan
Yes not unsual. It must close the meshes and depending on the components and the clipping shape it has to retriangulate in such a way that you can see additional triangles in some locations. I even faced some issue when there are some transitions between templates. Note that rectangular faces of the components are not always planar. That is a reason why some additional edges are required.
Ok and is it possible to add additional edges for road crossings for example?
Not sure to well understand what you want to add. Edges are mainly controlled by template interval, stroking (H and V set in feature definition), external points if used, key stations, clipping
