Rail Track has a possibility to turn on/off Horizontal or Vertical On-Alignment points. Is it possible to do that with OpenRail?
No. Unfortunately, if an interval is set then you will get only points at given interval. Cardinal points of H/V will not be reported.
Hi Ivar,
You can also set an interval of 0 to get Horizontal Cardinal points only. You might have to run the report a few times to get what you need.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
And what about Vertical Cardinal points?
Can't you just do that with a Geometry report?
I need station offset data at interval and horizontal/vertical cardinal points.
