I have recently installed Power Rail V8i SS10
When I import a geometry from graphics then I do a check horizontal integrity on the element, there is no information in the table. The table gives me the option to select, next last and first but no data is visible. Can anyone help?
Could be that all columns width are 0. You can try to move the cursor on the top left of the dialog in the column headers area and try to expand the invisible column.
Thank you for your answer, I used answer which was
For reference and please don't try this if you are not a 100% confident, but it worked for me with Rob Nice on the end of the phone.
First make sure that you have exited BRT.
As the problem lay deep in the registry, RUN REGEDIT
Follow the path shown below:
HKEY_CURRENT_USER>SOFTWARE>BENTLEY>APPLICATIONS>VERSION 8.11
Under VERSION 8.11 there is a directory "ListViewColumnSettings" delete it and restart BRT
I used this and it worked for me. To add to horizontal integrity table bit. I could see that on the screen the last can be seen and the first can be seen, as well as the previous and the next element. So it was a display issue, in that the columns were not created in the first place.
Yes this one is good as well. If you don't feel confident you can always export the registry key you want to delete.
