<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>How to delete Imported Points after Point import</title><link>https://communities.bentley.com/products/rail_design/f/openrail-forum/205196/how-to-delete-imported-points-after-point-import</link><description>After using &amp;quot;Import Points&amp;quot; tool from Rail-Import Points, I would like to delete points. Imported points are selected using the element select tool and the program crashes.
 Please advise if there is a way to remove points points after import.
 Thanks</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: How to delete Imported Points after Point import</title><link>https://communities.bentley.com/thread/617464?ContentTypeID=1</link><pubDate>Fri, 30 Oct 2020 17:16:53 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3588f936-6844-4d20-a38c-3d987e0b21c1</guid><dc:creator>Jacob Dean</dc:creator><description>&lt;p&gt;This may not be the end all solution, but I would try using the Key In menu to delete the points. Make a &amp;quot;Trash&amp;quot; level, select your points you want to delete, and add them to that new level. After that, open the Key In menu, and type &amp;quot;level element delete Trash&amp;quot;. The end of that key in command needs to be the name of the new level, but for my example, I left it as &amp;quot;Trash&amp;quot;.&lt;/p&gt;
&lt;p&gt;Regards,&lt;/p&gt;
&lt;p&gt;Jacob&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
