Bentley Openrail Cant Gradient Annotation
Hello to all
I am trying to design cant for a railway section and I noted that Cant Gradient in cant editor table is presented as a ratio ( run/rise). Also in plan and profile, the cant is annotated by ratio. In the EU, the standard limits are given in mm/m (per mille). I was trying to change the units to design file settings but the change doesn't affect the cant table editor or annotation. It is possible to annotate the Cant Gradient in "per mille" format? If yes, what is the procedure.
I have added a separate row to show the speed along alignment. The speed is displayed as text at every cant transition, it is possible to add a graph to show the speed fluctuations except the text to the separate row of the annotation table?
Nikolin
