When I create a report from OpenRail I have several different file formats available in the "save as type" (xml, html, alxs, doc and *.* all files)
When I try the same when the file is opened from ProjectWise can only select xml format.
Is there a variable defining output formats for reports?
It is a known issue that is fixed in next release. Actually you can right click on the sheet to export to Excel or open the xml in Excel afterward
I know the right-click option, but that's not quite the same.
But thanks for clearify that is't a bug.
Finn Mejding
CAD Manager
Railway and Metro
COWI
