Hello!
As the title suggests, i'm having some issues having the sleepers that I have created staying on top throughout the template drop, they seem to become partially hidden and in some areas they disappear completely!
I have attached below a little screenshot for reference.
Any help would be appreciated!
Difficult to answer. It is a matter of consistancy between template and sleepers. Typically having good vertical offset in the template regarding of the one set for the Create Sleepers command. Also having the same cant applied to both and correct template behavior for the cant.
This worked! Changing the vertical offset did the trick, thanks for your help!
Answer Verified By: jpln
