Hi, I want to create my feature definition for differents turnout that we use. Our turnout cell are very simples, basicaly 2 lines with an angle between them. But I just can't figure out how to create a turnout definition. The help file is almost empty. Does anybody have an idea what are the setting, how many element should be used in the feature definition? Do I need to create a curved element? I'm sure I am not the only one strugling with this?
Thanks for your time
A turnout is just a feature definition. There is a schematic in the help.
https://docs.bentley.com/LiveContent/web/OpenRail%20Designer-v9/en/GUID-C4B945E3-686A-4321-BF7F-3809A2C54C7C.html
Then it is just a matter of defining a geometry to go from mainline to branch (.1 or theo .1 to branch .3).The turnout description you have should give this, or you could find an average geometry by calculation or through drawing constructions
1134.Tunrout Calculator.xlsx
Answer Verified By: JeremieDL
