Hi All,
I am using OpenRail and creating cross-sections at every 20m.
I have divided my corridor into 2km sections and created cross-sections sheets which is taking 10-15min.
But while exporting into PDF I am using print organiser to export sheets. It is taking 30-45min for 2km section (like 20-30 sheets) taking more time and impacting other OpenRail sessions by slowing the process.
Is there any other way or tips to export sheets into PDF with less time.
Regards, Raghuram SV
Check you don't have "Rasterized" checked on your printing configuration
Hi Venkata, this looks to be a bug in OpenRail and ORD for the last few versions.
Try opening Print Organizer in Microstation CE Update 15.2 and you will see it print exponentially faster.
Mark
