Normaly side slope annotation is a drafting process. However, I noted that the clipped corridors cannot be annotated unless the clip has been removed. Did I miss something or the workflow has been designed like this. If designed as such, side slope annotation workflow cannot be used in large project's and shall remain one of the limitations to switch completely to ORD/L.
Any help please?
You are right, there are many limitations with this function, clipping is one. There is enhancement request for a manual tool to be able to produce annotation with freedom and also independently from a corridor.
