Hi
Once I activate the horizontal alignment there appears an unnecessary line in horizontal alignment.
Om
circle unwanted horizontal lines with active profile no unwanted line horizontal alignment without active profile
Strange except if some level or feature definition are off in the 2D Model and contain elements ruled to the horizontal alignment and its active profile.
Some additional elements could be displayed in the 2D model from the 3D Model if reference is ON in the 2D Model.Such element can appear only when an active profile exists if they are ruled to the active profile.
I don't know if it is the reason but it could be one.
Thanks for the reply.I donot created these extra lines . It automatically appearing.Even I try to make this save complex by automatically these extra lines appear. I think automatic saving complex and auto convert active profile has same problems.
I have same problems when I attach this alignment to AutoCAD.It generates these extra lines.I thought that this may be a problem with Autocad.I have reversed the process,I have attached AutoCAD with Open Rail there is no problem.
I had similar issue while making the profile active, but I have got these in profile view.
Please share your file with Bentley and flag the issue. Following is the solution from Bentley.
One approach to delete those "phantom" strings could be to add them in a "Junk" Level and then deleting the level:
Create a Junk level named Junk
Select the elements
Set the junk level active and click in the view so that the elements are moved to that level
Use keyin "level element delete Junk"
Hi Venkata,
Thanks for sharing your solutions. What is the reason this junk is created? Even we do not create it? How we can avoid such junks.
