How to handle non-parallel Horizontal Feature Constraints?
In OpenRail CONNECT
I have an alignment (see below) which is used as a Horizontal Feature Constraint, and applied to points in the template.  Then added as a corridor reference.
For example this could be the back of a platform or footprint of a structure.
My corridor/linear drop will extend to this horz constraint feature.  But how do I control the template to rotate/follow the feature at transverse angles? Is this possible?
At the moment I am seeing them skewed at these angled positions.
For example:
Blue arrow - points of the template drop, geometry is joined as expected
Yellow dash - Is it possible to place/rotate template drops at these transverse angles?  My template components, Drains, Kerbs, Fences etc would then follow the footprint
