I've started to work with OpenRail. Previously I was working with BRT SS2. I have an issue with adding templates to my corridor. I have horizontal and vertical alignment, corridor added. Previously I've opened template library. When I want to drop my template I have dialog window where I can't change any template and have only name "bentley.CifNET.Objects.String..."
Do You have any idea why I have this kind of issue ??
Hi Sebastian, It may be because of your template library is not in selected workspace template folder.
Open the template library before you apply template to your corridor.
Template library is part of workspace definition.
So first question is: which workspace are you using?
You must use one.
If it is the one you want to use, then you can check the variable that locates the template library (File>Settings>Configuration>Configuration variables:
