Failed to copy payload for OpenRail Designer Connect Edition
Hello, I'm receiving the "Failed to copy payload for OpenRail Designer Connect Edition" when installing OpenRail designer. Any solution to resolve the issue ?
[08C8:0538][2021-05-27T08:18:43]i001: Burn v3.10.3.3007, Windows v10.0 (Build 17134: Service Pack 0), path: C:\Users\0042772\AppData\Local\Temp\{DB2B4046-46DC-4532-9293-9172790EDBB2}\.cr\OpenRail Designer CONNECT Edition x64 10.05.00.30.exe
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeExeName' to value 'OpenRailDesigner'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]OpenRailDesigner\ActivationWizard.exe'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'NotODPackageIdExtractionList' to value 'NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeIF_PromptCloseApplication' to value 'openraildesigner'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\OpenRail Designer CONNECT Edition\'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\OpenRail Designer CE\'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'ConfigurationDirectory_V1' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'Custom_ConfigurationDirectory_Path' to value '[CommonAppDataFolder]Bentley\OpenRail Designer CE\Configuration'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;InstallDesktopShortcut;LumenRTInstallDirectory;LumenRTUserName;LumenRTCompanyName;SharedConfigurationDirectory'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;LumenRTInstallDirectory'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeKBBuddiName' to value 'MicroStation_KB_Requirements'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'PackageCacheHtmlHelpPageGuid' to value 'GUID-F0AAA55A-598A-408E-B326-342DA76E049D.html'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BundleHelpConfigurationWhatsNewChildHtml' to value 'GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{1C96804F-75C5-4205-A611-E588C8A311E2}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeBundleCulture' to value 'en'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeBuildType' to value 'Release'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeBundleShortName' to value 'OpenRailDesigner'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_OpenRailDesigner_en.zip'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'VBA_KB2803801_LANGUAGE_PRGID' to value '67804'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'LumenRTInstallDirectory' to value '[ProgramFiles64Folder]Bentley\Bentley LumenRT CONNECT Edition - Update 10'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{EA46248D-A876-4D46-81F2-1889AB3A3C03}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{2142CBF0-6950-3597-95C8-BCE5A44F31B4}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_CivilDesignWorkSpaceBundleModule' to value '{18E51D6F-6A5A-3AEB-BA57-A82968A4FF90}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{C3AA62D1-5794-4A9F-9FEB-B687DC7C338C}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_DgnIndexer' to value '{833E82FD-B939-4E95-9E8A-44A57B5EBD0B}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_DgnPreviewHandler' to value '{A73C1780-0589-48DA-956A-20A1FB7C1443}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
[08C8:0538][2021-05-27T08:18:43]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
[08C8:0538][2021-05-27T08:18:43]i009: Command Line: '"-burn.clean.room=C:\Open Rail\OpenRail Designer CONNECT Edition x64 10.05.00.30.exe" -burn.filehandle.attached=580 -burn.filehandle.self=600'
[08C8:0538][2021-05-27T08:18:43]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Open Rail\OpenRail Designer CONNECT Edition x64 10.05.00.30.exe'
[08C8:0538][2021-05-27T08:18:43]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Open Rail\'
[08C8:0538][2021-05-27T08:18:43]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843.log'
[08C8:0538][2021-05-27T08:18:43]i052: Condition 'VersionNT64 > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
[08C8:0538][2021-05-27T08:18:43]i000: Setting string variable 'WixBundleName' to value 'OpenRail Designer CONNECT Edition'
[08C8:0538][2021-05-27T08:18:43]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[08C8:0538][2021-05-27T08:18:43]i000: Loading managed bootstrapper application.
[08C8:0538][2021-05-27T08:18:44]i000: Creating BA thread to run asynchronously.
[08C8:4F90][2021-05-27T08:18:44]i000: Setting Culture Info to en
[08C8:4F90][2021-05-27T08:18:44]i000: Setting string variable 'BeSelectedLanguage' to value 'en'
[08C8:4F90][2021-05-27T08:18:44]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''
[08C8:4F90][2021-05-27T08:18:44]i000: BentleyBundle Version 11.04.00.17
[08C8:4F90][2021-05-27T08:18:44]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\0042772\AppData\Local\Temp\{FD190BAB-77CF-4A41-97C7-3FB75ED834BE}\.ba'
[08C8:4F90][2021-05-27T08:18:44]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\0042772\AppData\Local\Temp\{DB2B4046-46DC-4532-9293-9172790EDBB2}\.cr'
[08C8:4F90][2021-05-27T08:18:44]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Open Rail\'
[08C8:4F90][2021-05-27T08:18:44]e000: Using Layout File : C:\Users\0042772\AppData\Local\Temp\{FD190BAB-77CF-4A41-97C7-3FB75ED834BE}\.ba\Setup.lyt
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VisualBasicCore InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VisualBasicCoreKB2803801 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VisualBasicCoreKB3061498 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VisualBasicCorepatch InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VisualBasicLang InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VisualBasicLangPackKB2803801 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting DotNet452Full InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting VCRedistx64 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting BentleyConnectClient InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting ItgDgnDbImporter InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting PowerProductPackage InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,OptionalFeature,TechPreview,textfavoritestoken,issueresolutiontoken,assetmanagertoken,Configuration,FileAssociationFeature'
[08C8:4F90][2021-05-27T08:18:45]i000: Setting CivilDesignWorkSpaceBundleModule InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting PointTools32Extx86 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting DgnIFilterSetUpx64 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting DgnIndexer InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting DgnPreviewHandler InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting DgnThumbnailProvier InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting HDRPreviewExtension_x64 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]i000: Setting LumenRT2017 InstallLevel to 1
[08C8:4F90][2021-05-27T08:18:45]e000: LoadTestAutomationApp(): Failed to load test dll with error Object reference not set to an instance of an object.
[08C8:4F90][2021-05-27T08:18:45]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
[08C8:4F90][2021-05-27T08:18:45]i000: Setting string variable 'BePrimaryProductName' to value 'OpenRail Designer CONNECT Edition'
[08C8:4F90][2021-05-27T08:18:47]i000: Display is set to Full
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]i000: Register callbak=ProxySettingsPage
[08C8:4F90][2021-05-27T08:18:48]i000: Display Page=ProxySettingsPage
[08C8:4F90][2021-05-27T08:18:48]i000: Cannot Display Page=ProxySettingsPage
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductInstallDirSelectionUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductConfigurationSettingsUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductSelectionUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductFeatureSelectionUserControl.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /LumenRTExtension;v1.0.0.0;component/InstallDirSelection.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /LumenRTExtension;v1.0.0.0;component/LumenRTUserInformation.xaml
[08C8:4F90][2021-05-27T08:18:48]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RedefineWixPackageCacheUserControl.xaml
[08C8:0538][2021-05-27T08:18:48]i100: Detect begin, 19 packages
[08C8:0538][2021-05-27T08:18:48]i000: PCRA: Checking running instances.
[08C8:0538][2021-05-27T08:18:48]i000: PCRA: Command Action - Install
[08C8:0538][2021-05-27T08:18:48]i000: PCRA: Command Display - Full
[08C8:0538][2021-05-27T08:18:48]i000: PCRA: No running instances.
[08C8:0538][2021-05-27T08:18:48]i000: PCRA: Exiting from prompt.
[08C8:0538][2021-05-27T08:18:48]i000: KBDetectBegin: Current Image is not running from a Deployment Image.
[08C8:0538][2021-05-27T08:18:48]i000: KBDetectBegin: Current action is allowed to executed for KB check. ActionName=Install
[08C8:0538][2021-05-27T08:18:48]i000: KBDetectBegin: Variable BeSkipKBCheck is not set to a value, hence, continuing with KB check.
[08C8:0538][2021-05-27T08:18:48]i000: Trying to connect to BUDDI, Retry Count = 1. Local Retry Count = 1
[08C8:0538][2021-05-27T08:18:49]e000: ResolveBUDDIUrl: WebException The underlying connection was closed: An unexpected error occurred on a send.
[08C8:0538][2021-05-27T08:18:49]i000: Failed to check for Windows Updates with error Invalid URI: The URI is empty.
[08C8:0538][2021-05-27T08:18:49]i000: BeSkipKBCheck :
[08C8:0538][2021-05-27T08:18:49]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent
[08C8:0538][2021-05-27T08:18:49]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[08C8:0538][2021-05-27T08:18:49]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[08C8:0538][2021-05-27T08:18:49]i000: DetectBegin: Installed State of Package DetectedAbsent
[08C8:0538][2021-05-27T08:18:49]i000: Setting string variable 'BentleyConnectInstalledVersion' to value '10.00.18.013'
[08C8:0538][2021-05-27T08:18:49]i000: Registry key not found. Key = 'SOFTWARE\Bentley\Installed_LanguagePacks\{718972C7-007F-4F72-8AD5-5B0B750E2493}'
[08C8:0538][2021-05-27T08:18:49]i000: Setting numeric variable 'LanguagePackRegistry' to value 0
[08C8:0538][2021-05-27T08:18:49]i000: Registry key not found. Key = 'SOFTWARE\Bentley\LumenRT\Bentley LumenRT CONNECT Edition - Update 10'
[08C8:0538][2021-05-27T08:18:49]i000: Setting string variable 'NetFramework45Version' to value '528049'
[08C8:4F90][2021-05-27T08:18:49]i000: ErrorPage Code: 0
[08C8:0538][2021-05-27T08:18:49]i000: Product or related product not found: {1CC0EABA-3397-4893-833E-56BE22820105}
[08C8:0538][2021-05-27T08:18:49]i000: Setting numeric variable 'PRODSEARCHITG15INSTALLED' to value 2
[08C8:0538][2021-05-27T08:18:49]i000: Setting string variable 'VC14_vcredist_x64_Installed' to value '1'
[08C8:0538][2021-05-27T08:18:49]i106: Calculating patch applicability for target product code: {90120064-0070-0000-0000-4000000FF1CE}, context: Machine
[08C8:0538][2021-05-27T08:18:49]i106: Calculating patch applicability for target product code: {90F60409-7000-11D3-8CFE-0150048383C9}, context: Machine
[08C8:0538][2021-05-27T08:18:49]i052: Condition '(NetFramework45Version >= 394802)' evaluates to true.
[08C8:0538][2021-05-27T08:18:49]i052: Condition 'VC14_vcredist_x64_Installed' evaluates to true.
[08C8:0538][2021-05-27T08:18:49]i052: Condition 'BentleyConnectInstalledVersion >= v10.0.10.19' evaluates to true.
[08C8:0538][2021-05-27T08:18:49]i103: Detected related package: {AE4E79D2-D7DE-418F-9E7D-B58B62D7F4FA}, scope: PerMachine, version: 1.6.7.7, language: 0 operation: Downgrade
[08C8:0538][2021-05-27T08:18:49]i000: DetectRelatedMsiPackage: Operation=Downgrade
[08C8:0538][2021-05-27T08:18:49]i103: Detected related package: {A753B088-3FCE-4F1C-BF92-8E6931DE261E}, scope: PerMachine, version: 8.11.9030.0, language: 0 operation: MajorUpgrade
[08C8:0538][2021-05-27T08:18:49]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade
[08C8:0538][2021-05-27T08:18:49]i103: Detected related package: {74A8C1AF-75E5-4653-95AF-222725B7D877}, scope: PerMachine, version: 8.11.7.411, language: 1033 operation: MinorUpdate
[08C8:0538][2021-05-27T08:18:49]i000: DetectRelatedMsiPackage: Operation=MinorUpdate
[08C8:0538][2021-05-27T08:18:49]i052: Condition 'LumenRTInstalledVersion >= v16.10.02.62' evaluates to false.
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VisualBasicCore, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VisualBasicCoreKB2803801, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i105: Detected package: VisualBasicCoreKB2803801 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VisualBasicCoreKB3061498, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i105: Detected package: VisualBasicCoreKB3061498 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VisualBasicCorepatch, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i105: Detected package: VisualBasicCorepatch target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VisualBasicLang, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VisualBasicLangPackKB2803801, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i105: Detected package: VisualBasicLangPackKB2803801 target: {90F60409-7000-11D3-8CFE-0150048383C9}, state: Present
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: DotNet452Full, state: Present, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: VCRedistx64, state: Present, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: BentleyConnectClient, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: ItgDgnDbImporter, state: Obsolete, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: PowerProductPackage, state: Absent, cached: None
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: OptionalFeature, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: PPDesktopShortcut, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: TechPreview, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: textfavoritestoken, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: issueresolutiontoken, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: assetmanagertoken, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: Configuration, state: Absent
[08C8:0538][2021-05-27T08:18:49]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Absent
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: CivilDesignWorkSpaceBundleModule, state: Absent, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: PointTools32Extx86, state: Absent, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: DgnIFilterSetUpx64, state: Present, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: DgnIndexer, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: DgnPreviewHandler, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: DgnThumbnailProvier, state: Present, cached: Complete
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: HDRPreviewExtension_x64, state: Present, cached: None
[08C8:0538][2021-05-27T08:18:49]i101: Detected package: LumenRT2017, state: Absent, cached: None
[08C8:0538][2021-05-27T08:18:49]i000: Detect complete Start
[08C8:0538][2021-05-27T08:18:49]i000: Setting string variable 'BePlannedAction' to value 'Install'
[08C8:0538][2021-05-27T08:18:49]i000: ItgDgnDbImporter AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: ItgDgnDbImporter AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: ItgDgnDbImporter AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_TechPreview AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_issueresolutiontoken AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_issueresolutiontoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_issueresolutiontoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_textfavoritestoken AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_textfavoritestoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_textfavoritestoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PowerProductPackage_assetmanagertoken AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: CivilDesignWorkSpaceBundleModule AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PointTools32Extx86 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: PointTools32Extx86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: PointTools32Extx86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnIndexer AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: DgnIndexer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnIndexer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnPreviewHandler AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: DgnPreviewHandler AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnPreviewHandler AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnThumbnailProvier AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: DgnThumbnailProvier AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DgnThumbnailProvier AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCore AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCore AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCore AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCorepatch AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCorepatch AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicCorepatch AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicLang AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicLang AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicLang AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DotNet452Full AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: DotNet452Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: DotNet452Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VCRedistx64 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: VCRedistx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: VCRedistx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: LumenRT2017 AnalyzeFeatureConditions: LaunchAction=Install
[08C8:0538][2021-05-27T08:18:49]i000: LumenRT2017 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: LumenRT2017 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[08C8:0538][2021-05-27T08:18:49]i000: Detection complete planned action: Install
[08C8:0538][2021-05-27T08:18:49]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[08C8:0538][2021-05-27T08:18:49]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[08C8:0538][2021-05-27T08:18:49]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
[08C8:0538][2021-05-27T08:18:49]i000: SessionMutex: Creating new SessionMutex
[08C8:0538][2021-05-27T08:18:49]i000: SessionMutex: Creating Mutex with Name={fa0972f4-9fdf-432b-bd45-dc1f7a984bee}-InstallMutex
[08C8:0538][2021-05-27T08:18:49]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[08C8:0538][2021-05-27T08:18:49]i000: WixInstallBA::SilentPlan
[08C8:0538][2021-05-27T08:18:49]i000: Checking ADDLOCAL and REMOVE...
[08C8:0538][2021-05-27T08:18:49]e000: baApplication_DetectWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg
[08C8:0538][2021-05-27T08:18:49]i000: AutoCad Civil 3D ObjectEnabler:Searching
[08C8:0538][2021-05-27T08:18:49]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
[08C8:0538][2021-05-27T08:18:49]e000: baCustomConfigurationPath:Start
[08C8:0538][2021-05-27T08:18:49]i199: Detect complete, result: 0x0
[08C8:4F90][2021-05-27T08:18:55]i000: WixInstallBA::Plan
[08C8:4F90][2021-05-27T08:18:55]i000: WixInstallBA::SetupModel Plan
[08C8:4F90][2021-05-27T08:18:55]i000: SetupModel::Before Plan
[08C8:09EC][2021-05-27T08:18:55]i000: Before Plan Async
[08C8:09EC][2021-05-27T08:18:55]i000: SetupViewModel::Before Plan
[08C8:09EC][2021-05-27T08:18:55]i000: RequestState None
[08C8:09EC][2021-05-27T08:18:55]i000: IsAnythingToDownload: Demanded by PowerProductPackage
[08C8:09EC][2021-05-27T08:18:55]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1
[08C8:09EC][2021-05-27T08:18:56]e000: TryBUDDIConnection: WebException The underlying connection was closed: An unexpected error occurred on a send.
[08C8:09EC][2021-05-27T08:18:56]i000: RequestState None
[08C8:09EC][2021-05-27T08:18:56]i000: WixBAPackageProperties is null
[08C8:09EC][2021-05-27T08:18:56]i000: FeatureNodeMachineState.Present True
[08C8:09EC][2021-05-27T08:18:56]i000: RequestState Absent
[08C8:09EC][2021-05-27T08:18:56]i000: WixInstallBA::Before Plan Complete
[08C8:09EC][2021-05-27T08:18:56]i000: WixInstallBA::Engine Plan
[08C8:0538][2021-05-27T08:18:56]i200: Plan begin, 19 packages, action: Install
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'LumenRTInstallDirectory' to value 'C:\Program Files\Bentley\Bentley LumenRT CONNECT Edition - Update 10\'
[08C8:0538][2021-05-27T08:18:56]w321: Skipping dependency registration on package with no dependency providers: DotNet452Full
[08C8:0538][2021-05-27T08:18:56]w321: Skipping dependency registration on package with no dependency providers: VCRedistx64
[08C8:0538][2021-05-27T08:18:56]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient
[08C8:0538][2021-05-27T08:18:56]i204: Plan 9 msi features for package: PowerProductPackage
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_DefaultFeature_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_OptionalFeature_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: OptionalFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_PPDesktopShortcut_IsNotInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: PPDesktopShortcut, state: Absent, default requested: Unknown, ba requested: Absent, execute action: None, rollback action: None
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_TechPreview_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: TechPreview, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_textfavoritestoken_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: textfavoritestoken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_issueresolutiontoken_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: issueresolutiontoken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_assetmanagertoken_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: assetmanagertoken, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_Configuration_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: Configuration, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_IsInstalling' to value '1'
[08C8:0538][2021-05-27T08:18:56]i203: Planned feature: FileAssociationFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleRollbackLog_PowerProductPackage' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_000_PowerProductPackage_rollback.log'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleLog_PowerProductPackage' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_000_PowerProductPackage.log'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleRollbackLog_CivilDesignWorkSpaceBundleModule' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_001_CivilDesignWorkSpaceBundleModule_rollback.log'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleLog_CivilDesignWorkSpaceBundleModule' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_001_CivilDesignWorkSpaceBundleModule.log'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleRollbackLog_PointTools32Extx86' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_002_PointTools32Extx86_rollback.log'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleLog_PointTools32Extx86' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_002_PointTools32Extx86.log'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'WixBundleLog_DgnThumbnailProvier' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843_003_DgnThumbnailProvier.log'
[08C8:0538][2021-05-27T08:18:56]w321: Skipping dependency registration on package with no dependency providers: LumenRT2017
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VisualBasicCore, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VisualBasicCoreKB2803801, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VisualBasicCoreKB3061498, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VisualBasicCorepatch, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VisualBasicLang, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VisualBasicLangPackKB2803801, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: DotNet452Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: VCRedistx64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: BentleyConnectClient, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: ItgDgnDbImporter, state: Obsolete, default requested: None, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: PowerProductPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: CivilDesignWorkSpaceBundleModule, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: PointTools32Extx86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: DgnIFilterSetUpx64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: DgnIndexer, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: DgnPreviewHandler, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: DgnThumbnailProvier, state: Present, default requested: Present, ba requested: Present, execute: MinorUpgrade, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: HDRPreviewExtension_x64, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[08C8:0538][2021-05-27T08:18:56]i201: Planned package: LumenRT2017, state: Absent, default requested: Present, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[08C8:0538][2021-05-27T08:18:56]i000: GetWindowsRootDriveName (): winRoot=C:\
[08C8:0538][2021-05-27T08:18:56]i000: IsPathRooted (C:\): true
[08C8:0538][2021-05-27T08:18:56]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=1896864, FileName=C:\Open Rail\OpenRail Designer CONNECT Edition x64 10.05.00.30.exe
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=1896864
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=859374689, NewSize=861271553
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=861271553
[08C8:0538][2021-05-27T08:18:56]i000: GetDriveName (C:\): DriveInfo.Name=C:\
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): DriveName=C:\, Path=C:\Program Files\Bentley\OpenRail Designer CONNECT Edition\
[08C8:0538][2021-05-27T08:18:56]i000: Warning : Install root drive C:\ is same as windows root drive C:\. Only C:\ will be check for available disk space.
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=4177259646, NewSize=5038531199
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Configurations. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Application Options. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = File association. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Desktop Shortcut. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Technology Preview Features. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Issue Resolution Service. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Text Favorites Manager. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature is not a package = Asset Manager. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=5038531199
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=423067168, NewSize=5461598367
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=5461598367
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2393945, NewSize=5463992312
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN IFilter. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley Dgn Index Service. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN Preview Handler. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley DGN Thumbnail Provider. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = HDR Preview. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64). Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB2803801). Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (KB3061498). Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = VBA Patch. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual Basic for Applications 7.1 (x64) English. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.2. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.23026. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Feature already installed = CONNECTION Client. Next
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=5463992312
[08C8:0538][2021-05-27T08:18:56]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2117135928, NewSize=7581128240
[08C8:0538][2021-05-27T08:18:56]i000: checkInstallSize (): Checking for drive C:\
[08C8:0538][2021-05-27T08:18:56]i000: checkInstallSize (): Requested Drive-List contains drive C:\
[08C8:0538][2021-05-27T08:18:56]i000: checkInstallSize (): Checking for drive E:\
[08C8:0538][2021-05-27T08:18:56]i000: validateInstallSize (): Result=True
[08C8:0538][2021-05-27T08:18:56]i000: PlanComplete: Called
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_Configuration_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_OptionalFeature_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_FileAssociationFeature_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_TechPreview_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_issueresolutiontoken_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_textfavoritestoken_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PowerProductPackage_assetmanagertoken_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'CivilDesignWorkSpaceBundleModule_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'PointTools32Extx86_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'DgnIFilterSetUpx64_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'DgnIndexer_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'DgnPreviewHandler_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'DgnThumbnailProvier_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'HDRPreviewExtension_x64_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VisualBasicCore_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VisualBasicCoreKB2803801_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VisualBasicCoreKB3061498_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VisualBasicCorepatch_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VisualBasicLang_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VisualBasicLangPackKB2803801_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'DotNet452Full_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'VCRedistx64_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'
[08C8:0538][2021-05-27T08:18:56]i000: WixInstallBA::Apply
[08C8:0538][2021-05-27T08:18:56]i000: WixInstallBA::Engine Apply
[08C8:0538][2021-05-27T08:18:56]i299: Plan complete, result: 0x0
[08C8:0538][2021-05-27T08:18:56]i300: Apply begin
[08C8:4F90][2021-05-27T08:18:56]i000: ErrorPage Code: 0
[08C8:0538][2021-05-27T08:18:56]i010: Launching elevated engine process.
[08C8:0538][2021-05-27T08:19:04]i011: Launched elevated engine process.
[08C8:0538][2021-05-27T08:19:04]i012: Connected to elevated engine.
[2FF4:4FD4][2021-05-27T08:19:04]i358: Pausing automatic updates.
[2FF4:4FD4][2021-05-27T08:19:04]i359: Paused automatic updates.
[2FF4:4FD4][2021-05-27T08:19:04]i360: Creating a system restore point.
[2FF4:4FD4][2021-05-27T08:19:04]w363: Could not create system restore point, error: 0x80070422. Continuing...
[2FF4:4FD4][2021-05-27T08:19:04]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fa0972f4-9fdf-432b-bd45-dc1f7a984bee}, options: 0x7, disable resume: No
[2FF4:4FD4][2021-05-27T08:19:04]i000: Caching bundle from: 'C:\Users\0042772\AppData\Local\Temp\{FD190BAB-77CF-4A41-97C7-3FB75ED834BE}\.be\Setup_OpenRailDesignerx64_10.05.00.030.exe' to: 'C:\ProgramData\Package Cache\{fa0972f4-9fdf-432b-bd45-dc1f7a984bee}\Setup_OpenRailDesignerx64_10.05.00.030.exe'
[2FF4:4FD4][2021-05-27T08:19:04]i320: Registering bundle dependency provider: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee}, version: 10.5.0.30
[2FF4:4FD4][2021-05-27T08:19:04]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fa0972f4-9fdf-432b-bd45-dc1f7a984bee}, resume: Active, restart initiated: No, disable resume: No
[08C8:0538][2021-05-27T08:19:04]i000: Installation chain initiated package from
[2FF4:4FD4][2021-05-27T08:19:04]i323: Registering package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, version: 7.1.00.00, package: VisualBasicCore
[2FF4:4FD4][2021-05-27T08:19:04]i325: Registering dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore
[08C8:06F0][2021-05-27T08:19:04]w343: Prompt for source of package: PowerProductPackage, payload: PowerProductPackage, path: C:\Open Rail\OpenRailDesignerx64.msi
[2FF4:4FD4][2021-05-27T08:19:04]i323: Registering package dependency provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, version: (null), package: VisualBasicCoreKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i325: Registering dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package: VisualBasicCoreKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i323: Registering package dependency provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, version: (null), package: VisualBasicCoreKB3061498
[2FF4:4FD4][2021-05-27T08:19:04]i325: Registering dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package: VisualBasicCoreKB3061498
[2FF4:4FD4][2021-05-27T08:19:04]i323: Registering package dependency provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, version: (null), package: VisualBasicCorepatch
[2FF4:4FD4][2021-05-27T08:19:04]i325: Registering dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package: VisualBasicCorepatch
[2FF4:4FD4][2021-05-27T08:19:04]i323: Registering package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, version: 7.1.0.0, package: VisualBasicLang
[2FF4:4FD4][2021-05-27T08:19:04]i325: Registering dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang
[2FF4:4FD4][2021-05-27T08:19:04]i323: Registering package dependency provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, version: (null), package: VisualBasicLangPackKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i325: Registering dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package: VisualBasicLangPackKB2803801
[08C8:06F0][2021-05-27T08:19:04]i000: ResolveSource: Retries value 1
[08C8:06F0][2021-05-27T08:19:04]i000: ResolveSource: Checking with PayloadService package PowerProductPackage
[08C8:06F0][2021-05-27T08:19:04]e000: WaitForProxyAuthentication: Waiting for proxy authentication
[08C8:06F0][2021-05-27T08:19:04]i000: No Internet Connection, cannot resolve url for PackageId PowerProductPackage
[08C8:06F0][2021-05-27T08:19:04]e054: Failed to resolve source for file: C:\Open Rail\OpenRailDesignerx64.msi, error: 0x80070002.
[08C8:06F0][2021-05-27T08:19:04]e000: Error 0x80070002: Failed while prompting for source (original path 'C:\Open Rail\OpenRailDesignerx64.msi').
[08C8:06F0][2021-05-27T08:19:04]e313: Failed to acquire payload: PowerProductPackage to working path: C:\Users\0042772\AppData\Local\Temp\{FD190BAB-77CF-4A41-97C7-3FB75ED834BE}\PowerProductPackage, error: 0x80070002.
[08C8:06F0][2021-05-27T08:19:04]e000: Caching failed for PowerProductPackage
[08C8:0538][2021-05-27T08:19:04]e000: Error 0x80070002: Cache thread exited unexpectedly.
[08C8:4F90][2021-05-27T08:19:04]i000: ErrorPage Code: -2147024894
[2FF4:4FD4][2021-05-27T08:19:04]i326: Removed dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package VisualBasicLangPackKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i329: Removed package dependency provider: {1239B802-D3D7-46AB-BAD8-E701B4B50422}, package: VisualBasicLangPackKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i326: Removed dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package VisualBasicLang
[2FF4:4FD4][2021-05-27T08:19:04]i329: Removed package dependency provider: {90F60409-7000-11D3-8CFE-0150048383C9}, package: VisualBasicLang
[2FF4:4FD4][2021-05-27T08:19:04]i326: Removed dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package VisualBasicCorepatch
[2FF4:4FD4][2021-05-27T08:19:04]i329: Removed package dependency provider: {9DC3393B-AF62-4DF3-9EE5-462764292BBF}, package: VisualBasicCorepatch
[2FF4:4FD4][2021-05-27T08:19:04]i326: Removed dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package VisualBasicCoreKB3061498
[2FF4:4FD4][2021-05-27T08:19:04]i329: Removed package dependency provider: {CFE4A7A6-F4F4-4EB0-B70B-DFC0DBF112B3}, package: VisualBasicCoreKB3061498
[2FF4:4FD4][2021-05-27T08:19:04]i326: Removed dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package VisualBasicCoreKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i329: Removed package dependency provider: {B61407A7-014B-4046-9E00-EC7285F85BDA}, package: VisualBasicCoreKB2803801
[2FF4:4FD4][2021-05-27T08:19:04]i326: Removed dependency: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee} on package provider: {90120064-0070-0000-0000-4000000FF1CE}, package VisualBasicCore
[2FF4:4FD4][2021-05-27T08:19:04]i329: Removed package dependency provider: {90120064-0070-0000-0000-4000000FF1CE}, package: VisualBasicCore
[08C8:0538][2021-05-27T08:19:04]i000: Installation chain finished package from
[2FF4:4FD4][2021-05-27T08:19:04]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fa0972f4-9fdf-432b-bd45-dc1f7a984bee}, resume: None, restart: None, disable resume: No
[2FF4:4FD4][2021-05-27T08:19:04]i330: Removed bundle dependency provider: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee}
[2FF4:4FD4][2021-05-27T08:19:04]i352: Removing cached bundle: {fa0972f4-9fdf-432b-bd45-dc1f7a984bee}, from path: C:\ProgramData\Package Cache\{fa0972f4-9fdf-432b-bd45-dc1f7a984bee}\
[2FF4:4FD4][2021-05-27T08:19:04]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{fa0972f4-9fdf-432b-bd45-dc1f7a984bee}, resume: None, restart initiated: No, disable resume: No
[08C8:0538][2021-05-27T08:19:04]i000: C:\Program Files\Bentley\OpenRail Designer CONNECT Edition\OpenRailDesigner\ActivationWizard.exe application is set for launch after installation
[08C8:0538][2021-05-27T08:19:04]i000: application not found to launch after installation
[08C8:0538][2021-05-27T08:19:04]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\0042772\AppData\Local\Temp\OpenRail_Designer_CONNECT_Edition_20210527081843.zip'
[08C8:0538][2021-05-27T08:19:04]e000: baApplication_ApplyCompleteWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg
[08C8:0538][2021-05-27T08:19:04]i399: Apply complete, result: 0x80070002, restart: None, ba requested restart: No
