Hi!
The Place Cell/Block tool in Power Rail Track does not drop the cells we currently have on skewed cross sections (since the cuts along the tracks do not match the existing bridge skews). Like the text for the name of the alignments, cants, elevations, and etc. come up after the tool is used but the cell itself doesn’t show up.
I was previously able to use this tool to insert the cells when I was using generic Inroads (still not entirely familiar with the different packages – but the one that required you to add in certain suites to get additional add-ons like track and etc. every time it was opened), but haven’t able to do so Power Rail Track.
Do you know if there’s a workaround for this (shown below is a label with how the cells should be placed relative to the track label (on a non-skewed section) and a sample skewed section with just the track labels with an existing flat surface line - the existing surface and track labels were adjusted since I'm not able to disclose any project related info) – aside from manually inserting the cells and adjusting it for the cant and etc.?
Thanks a bunch for your help!
I am not aware of any workaround. I was not aware of this issue either. So I would say manual placement
