I would like to manually configure the export to IFC selecting in OpenRail designer. is there a built-in funcitonality that allows datamapping to IFC? Is it possible to read the content of the .rose files in the directory C:\Program Files\Bentley\OpenRail Designer CONNECT Edition\OpenRailDesigner\ECSchemas\RailwayIFC carring the IFC implemented schema?
As far as I know it is not possible to manage mapping. I will check anyway.
Hi Carla,
You can do this in the iModel Hub if your organization has access:
Export to IFC - Synchronization Wiki - iTwin Services - Bentley Communities
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: jpln
Thank you Mark!
