I'd like to place 3D sleepers along an alignement in ORD. Currently, I can only see the possibilty to place simple cuboids. Is there a way to use more complex (=more realstic) objects, like this?:
Same question for 3D-Rails...
you can use populate command from MicroStation visualization tools. You need a surface below the sleepers to project the sleepers (cells) onto.
Generative component is the other solution. Look at Generative Component community. There is a very nice video about rail on the learn server.https://communities.bentley.com/products/products_generativecomponents/w/generative_components_community_wiki/41876/suggested-training-sequence
we are expecting sleepers as individual cells with 2021 R2 (Q4 2021)
