I have one technical issue to solve can you please help me.
I just created one test corridor using a double-track template.
Template origin was mainline which is a straight track and for the 2nd track, I gave the point control to the branching track which is a curved track.
1) In the first test on the plan the ballast top width for mainline is 3.4m(as measured perpendicular to mainline) and ballast width on branching line is 3.3m(as measured perpendicular to branch line) further ahead in some places on branch line it is 3.2m. which is incorrect it should be 3.4.2) In the second test I converted the plan drawing to 2d and measured it again but the result was the same.3) In the Third test I created the cross-section, which is along the mainline, in cross-section also it was shown the width as 3.2 or 3.3 for the branch line.4) Fourth test, this is interesting I used the secondary alignment option to create the cross-section and the result was correct the ballast width on the branch line is 3.45
My conclusion
As per procedure and software, the design is correct. And somehow following the 4th test we can create the cross-sections showing the correct widths.
The major problem is with the plan drawing, as these will be shared with various departments like drainage, roads, electrical, signaling, and Construction for them the width (ballast, sub-ballast, and formation layer) needs to be correct. Which in this case is not true? And they created the wrong design as they considered the width and embankment footprint.
For better results, we can create a separate corridor for each line, which will minimize the error, but for many tracks in yards, it will become more difficult to generate a corridor for each line. And this problem is always near to turnouts junctions which sometimes hard to identify.
Please share your views or solution where we can get the correct widths on the branching line.
Please notify, if any other information or data is needed.
If I were you, I would move this post to the OpenRail forum - you will asking rail people rail questions (this forum is more road focused).
https://communities.bentley.com/products/rail_design/f/openrail-forum#pifragment-26016=1
Use the 'More > Move' link at the bottom of your post to move it.
Thank you for the information. I moved this post to the open rail forum. But I believe the road professional can also answer this query.
Plan/3D/Cross sections are always the same.
Using branch alignment as secondary alignment means that points beyond this secondary alignment are calculated perpendicular to this alignment. That is why it gives the good width. The issue is always between tracks. Thinking construction makes things often easier.
So you always need to consider how it will be built and accuracy you must achieve. It could be different for subballast and ballast. So you may use one template along main line for subballast and one corridor per track for ballast.
For plan you must display what is designed by the corridor.
Thank you for your reply, my first approach to this problem was the same as you suggested. but it becomes very tedious work if we have more than 20 to 30 tracks in a yard. it is a general way of designing the yards that most of us use the multi-track template and most of the time it works perfectly because tracks are almost parallel. But I am facing this problem near to turnout junctions. When I compared the plans and cross-section generated it is not matching. So my main intention here is that does anybody realizes this error and applied some settings to rectify the skewness on the branching track.
Yes of course, I always, everything is easy when parallel. That's true for rail, roads, etc. The complexity comes with variations of the direction of the computation. It can be partially solved by secondary alignment.
However, I don't understand the issue you are facing between plan/3D/cross section.What your plan is made of? Something different than 3D?
