Constraint point needs to be set in the middle
Hello all,
I am trying to set up the middle point between 2 centrelines.
These centrelines are connect to control points of the template.
I am wondering if anyone have been solving this issue previously as I am trying to make it for a bit while.
Example:
if the centrelines are from each other 4m, the middle point is 2m away each of them; if 6m so 3m away from them etc. My maximum is a bit over 8m.
I am not sure about equation as I didn't use it yet. If you can suggest possible solution, this will be greatly appreciate.
Thank you. L
