Hello.
I want to trim the right runner with the left one:
as crop reference I select the left corridor:
but I don't get the expected result (green):
how can it be solved? Thank you!
(attached 2 runners)CC_OBL_TRF_Via1_Alineacio.dgnCC_OBL_TRF_Via1_Balasto.dgnCC_OBL_TRF_Via2_Balasto.dgn
Hi Santiago,
This should help:
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/19151/video-target-aliasing-and-corridor-clipping
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 17 | ProjectWise CE 3.4
Thanks mark.
The video you sent me is the correct one for trimming slopes, but I want to trim template components:
in the right corridor, I create clipping reference:
is created fine:
but there must be a problem, it has not been clipped:
please, do you know where the problem is?
Thanks!!
You need to apply Target Aliasing to the left Corridor so its slope stops at its intersection with the other and then clipping of the right corridor will give you the result you need.
The reason it is not clipping correctly is because the left corridors slope is targeting the ground surface and overlaps the right one.
