I am trying to use the export corridor to IFC command and getting the below warnings from message centre.
And getting the below error and no file is created.
Take advantage of this Technology Preview, a non-public software service and/or application for evaluation purposes only. Please use the Technology Preview in your normal business environment as needed to form an opinion concerning the performance of the Technology Preview. Bentley personnel would welcome your valued feedback concerning the performance of the Technology Preview as you evaluate the capabilities. Please be aware that at some point, you may receive notice from Bentley that such use must cease or this Technology Preview will become unavailable to you. As we receive feedback, this Technology Preview may also be enhanced, updated or also discontinued without notice. As a Technology Preview, it is provided to you "as-is" without the benefit of any Bentley warranty, indemnity or support obligation. Thank you!
Can anyone advise what the issue is here?
I have experienced the same in 2021 R1.
In 2021 R2 you get more options, so you might want to upgrade.
It is not an error but a warning. Note that it only exports civil meshes created by corridors and create rails and sleepers command.If you do'nt have such elements then it won't export anything.
There is also the alignment export to IFC in the geometry ribbon.
Thanks jpln
My understanding was the same. However I am getting no output when using crate rails command, if not an error what is the solution or am I missing something obvious?
In a new ORD metric seed I tested the below:
1. Geometry > Import geometry (.alg)
2. Rail > Rail and Sleepers > Create Rails (Select Centreline and using the defautl ORD Single Rail Template)
3. Home > Export to IFC (Boundary Name <None>)
Prompts me to save the IFC file and nothing is saved when checking in windows explorer.
I successfully exported just the rails. So maybe something wrong with the file or the installation. Could you share the dgn so I can test it?
