Hello all,
I have updated software in March/2022.
The referenced file going through the drawing production and at the end this came up to me.
Any suggestions?
Thank you, Lenka
Hi Lenka
See if this forum thread helps you:
communities.bentley.com/.../ord---a-civil-3d-model-must-exist-in-order-to-create-civil-cross-section-boundaries
Hi Grzegorz, I found this tread, thank you.
The solution is found, but honestly, after 6 hours of trying out the combination.
The reason is not known yet. The referenced file is 3D seed as this have been provided by 3rd party this have been just referenced with the live nesting 15 as 99 was too much.
Turned off the level as the text I didn't need.
Referenced geometry of alignment.
I have clicked to the attach reference window( but this not make it work I bet).
Sorry to anyone who try to find answer, I do not know.
From what I found you need to have control view on( 2D/3D), Active terrain.
One normal workflow for Xsections drawing production is:
