Coach Sweep with Curve Elements in Template
All
Finally got round to getting and installing OpenRail Designer in my new organisation. Learning as I go and have dived straight into seeing if we can do simple gauging with Coach Sweep.
I have a Loading Gauge Vehicle template that I have brought into my template library and created the necessary constraints and cant points with superelevation flags. All of this is working well.
I am however having an issue with the curved element that forms the top of the vehicle envelope between the two cantrails. When the coachsweep creates the swept path, this element is faceted/stroked by 4 points.
So instead of having a nice curve, I have a 4 point curve that doesn't sufficiently represent my vehicle.
I have tried the variable in the link below, but I don't think this is for Coach Sweep Curved elements
Circular Component - Stroke value for mesh creation - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
I can go in and remake the template and apply my own stroking, but would like to see if there is a way to get this done without doing this.
Al
