when select the alignment , it doesn't show the distance , radius etc.
alignment couldnot be modified in place . Only table editor available.
check handles are ON on the Select Element tools settings dialog
Answer Verified By: Himansu Panda
thanks
This doesn't seem to work for all alignments.
I have two alignments, both with the same feature definition, but only one of them shows me modification options
The handles sometimes disappear when changing feature definitions in plan.
Difficult to say what can be wrong here if handles are ON, no lock on the element and rules activated. What is the version?
And I am adding a more obvious reason: the 3D is displayed in the 2D and you select the 3D instead of the 2D.
You can turn off the 3D in the 2D and/or send the reference to the back (update sequence or F10) so that active model elements are selected first.
