I am having an issue with turnouts. I place the turnout as normal and then either create the geometry off of the back of it or join into geometry previously created and then I complex it to create a continuous branch alignment. When I go to create a turnout report I can't see any information saying what the branch alignment is, I use this report from PRT as a way to check that the start stations of branch routes match that of the toe chainage for the mainline. See below the ORD report I get:
I followed the process as per: https://www.youtube.com/watch?v=6qNaQf1P2Kk . Have I missed a step?
Aware this is from an older version (I am using 2021 R2)
Thanks in advance
You are correct, this information is not available. I don't think it has ever been available in OpenRail.
I filled an enhancement request: https://dev.azure.com/bentleycs/Civil/_workitems/edit/904202
Answer Verified By: R M
Hello.Im working with PowerRailTrack SS10.And I have a similar issue.I placed double turnouts, But when i get the branch report I just have one of the two branches.
