When using Open Rail for exporting an Alignment to LandXML, the Station Equation at the XML does not have the full information. Let me explain with an example:
This is what I expect to find, exporting using Power Rail Track V8i:
<Alignments>
<Alignment ... staStart="77215.1" ...>
<StaEquation staAhead="215.1" staBack="77215.1" staInternal="77215.1">
<Feature code="StaEquation">
<Property label="bckEqn" value="" />
<Property label="ahdEqn" value="KM77+" /> <!-- THIS IS THE INFORMATION I WANT -->
</Feature>
</StaEquation>
</Alignment>
</Alignments>
This is the problem, exporting using OpenRail Designer version 10.10:
<Alignment ... staStart="215.1" ...>
<StaEquation staAhead="215.1" staBack="215.1" staInternal="215.1" />
<!-- NO MORE INFORMATION -->
Does anybody knows how to export LandXML in order to include also the Kilometer information (as show on the XML above) ?
It is a known issue.
Station Equation name is not exported in LandXML - Regression from Rail Track/Inroads (https://dev.azure.com/bentleycs/Civil/_workitems/edit/825874)
Equation Name is not explicitely defined in the LandXML schema. It needs to be added as custom feature. Something we did in Rail Track and not yet in OpenRail/OpenRoads. So actually Station Equation are well defined in the XML but with no name.
Answer Verified By: Raul C.C.
Hi,Thank you very much for the clarification.I look forward to see the development of this issue.
