I'm trying to annotate a horizontal curve with entry and exit spiral lengths, but the text favorite doesnt seem to work for "Curve Set Entry/ Exit Spiral Length".
is there something I am missing?
Using OpenRail 10.10.21.04
I don't experience any issue on a quick test. But you must use this curveset textfavorites with annotation at curvesets in the annotation definition.
I tried that, but it still doesn't work.
Even using Civil Labeler it is not shown correctly.
It may be that I don't completely understand the definition of curve sets. I noticed, that it does indeed work, when you have a tangent-transition curve-curve-transition curve-tangent. But when you have a reverse curve, it doesn't seem to work.
There is a bug. I created a defect: dev.azure.com/.../906170
Note that only some Bentley colleagues could use the link for fast access to the item. The number is the one you may find in release not for bug fixing in the future.
Thank you.
Maybe you could also look into how to make it possible to also annotate the cant points (Applied rate of Change, Deficiency Rate of change etc.) in the entry- and exit transition curve.
And a follow up question; is it possible to annotate for two (or more) speed profiles? If not, this is also a valuable feature to have.
