Estoy utilizando OpenRail Designer CE-2021 Release 1 Update 10, cuando intento generar los raíles en un modelo 2D en el que he referenciado los ejes con su tabla de velocidad y su cant, me sale el siguiente error, obtenido del fichero de texto *.log que se genera
Exception caught in source file e:\builds\cif10100103\Source\Cif\src\managed\ui\tools\PrimitiveCommand\PrimitiveCommand.cs at method OnDataButtonInternal
================================================================================Exception : Referencia a objeto no establecida como instancia de un objeto.
In Assembly : Bentley.CifNET.LinearGeometry.4.0
Stack Trace : en Bentley.CifNET.LinearGeometry.LinearElement.SetBcLinearEl(IBcLinearEl* linearEl) en Bentley.CifNET.LinearGeometry.LineString3d..ctor(DPoint3d[] points) en Bentley.Civil.Rail.GeometryModel.RailTrackEvaluator.GenerateGeometry(IEnumerable`1 railPoints, Double gapAtStart, Double gapAtEnd) en Bentley.Civil.Rail.GeometryModel.RailTrackEvaluator.EvaluateLeftRailGeometry() en Bentley.Civil.Rail.GeometryModel.RailTrackComponentRule.CreateRailTrackComponents(IObjectTracker objectTracker, ILinearEntity2dFactory linearEntityFactory, ILinearEntity2dFactory insideRailfactory) en Bentley.Civil.Rail.GeometryModel.RailTrackComponentRule..ctor(IObjectTracker objectTracker, CivilModel civModel, PlanSpace planSpace, RailTrackComponent railTrack, DistanceDefinition distanceDefinition, ILinearEntity2dFactory factory, ILinearEntity2dFactory insideRailfactory) en Bentley.Civil.Rail.GeometryModel.RailModel.CreateNewRailTrack(IObjectTracker objectTracker, RailTrackSettings reference, String rootName, DistanceDefinition distances, ILinearEntity2dFactory factory, ILinearEntity2dFactory insideRailfactory) en Bentley.Civil.RailwayDesigner.Commands.CreateRailsCommand.CreateRailTrack() en Bentley.Civil.RailwayDesigner.Commands.CreateRailsCommand.MoveToNextState() en Bentley.CifNET.UI.Tools.ParameterEntryState`2.Entered() en Bentley.CifNET.UI.Tools.ParameterEntryState`2.InternalPrimitiveParameterState.OnParameterAccepted(AcceptMethod acceptMethod, Object parameterValue) en Bentley.CifNET.UI.Tools.ParameterState.DoParameterAccepted(AcceptMethod acceptMethod, Object parameterValue) en Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.PromptDialogManagerOnDialogResult(Object sender, DialogResultEventArgs e) en Bentley.CifNET.UI.Tools.CursorPrompt.PromptDialogManager.SetResult(Object value, AcceptMethod acceptMethod) en Bentley.CifNET.UI.Tools.CursorPrompt.ParameterPromptManager.Bentley.CifNET.UI.Tools.ICommandParameterPrompter.OnDataPoint(IButtonEvent pointEvent) en Bentley.CifNET.UI.Tools.PrimitiveCommand.<>c__DisplayClass107_0.<OnDataButtonInternal>b__0() en Bentley.CifNET.UI.Tools.PrimitiveCommand.ManagedBooleanCallBack(Func`1 method, Boolean exitCommandAndCleanupCaches, Boolean retValue, String message, String memberName, String sourceFilePath, Int32 sourceLineNumber)
Y obviamente no hay ni rastro de los rieles, alguna sugerencia?
The first idea is an issue/bug with the geometry. Something to submit to support.
