Hi. After I have created my cross section set I would like to turn of and turn on some references and have it apply to all the sections at once. Furthermore I would like to turn off a couple of levels in some of the references and make sure this setting apply to all the sections at once. So my questions is, is there a way to update levels and reference settings for all the sections at once so I don't have to go into each section and change the settings after creating the section set?
It can be done with this tool:
Video: OpenRoads Level Display Batch Processor - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
Answer Verified By: Rasmus Molbæk
Hi Rasmus,
This should help and allow you to control all level display properties using you Default-3d model:
communities.bentley.com/.../cross-section-saved-views-settings
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Thanks a lot. Will have a look into that.
Thanks a lot!
