I cannot find the option for making clearance reports in OpenRail Designer.
How does this work?
ORLD 10.10.21.04
The clearance report as known in Rail Track does not exist in OpenRail. There is an enhancement request (821479) for it.
Main thing that is not available is to report according to the track plane.
Station offset and station base reports are available to report H+V offset.
And you must combine with other report such as cant report. It is often requested in the same report (also requested in the same enhancement request).
Answer Verified By: EBlach
