Issue with IFC files export.
     When creating IFC files I have a some issue. I'm creating corridor using corridor modeling and then I use a tool "Place Node" to add some surrounding infrastructure. Before using tool "export to IFC"  I'm changing  all designed Nodes with tool "mesh from element" to mesh elements (only mesh elements could be exported to IFC file).  Unfortunately many of them doesn't show in IFC file. For example I'll put screen with  added node in ORD, displays correctly , and below screen from BIMVision, where only some elements of this node exported to IFC file. Maybye someone has experience  with this kind of troubles while creating IFC files.
Parents Reply
  • Hi Will,
        Thanks for solution, but I have few questions, doubts :
    1) Is Your solution based on a Autodesk product "Revit" or is just a coincidence of names ?
    2) If answer for the first question is "yes", do You know any other method which is based on OpenRail or maybe Bentley products ?
    3) I have doubts about doing this in Revit, because rail design is specific. It has a kilometers long corridor and as I know Revit has a limits in design space which can be exported to 3d. Maybe something has changed but I remember issues like this reported by my colleagues from bridge team.
    4) I don't see any "screenshot below". Maybe something wasn't attached properly.
